Projection differences in 2D and 3D environments
1177
09-23-2022 06:25 PM
sandiegomonedero
Hi, Due to the projection differences in 2D and 3D maps we are not able to use the same mapserver and/or kml ground overlay to work on both environments (see image).  Is there any way to force the 2D and 3D  maps to have the same projection so that PNGs from a kml and/or a mapservice will work fine in both environments at the same time? any ideas on how to fix this?
Thanks
PS: We are able to modify the PNG so that it works in 3D,  but then it obviously does not work on 2D and we are forced to create two different map-services.
Tags (3)
