Project with Transformation - where to get projection engine file?
2314
05-22-2020 02:10 AM
WaldemarNowak
I try to use projection with specific transformation for bigger accuracy. In my case I need to convert from
  • WGS84 (WKID=4326
to
  • EPSG:2229 NAD83 / California zone 5 (ftUS)
using the best transformation for Southern California:
  • NAD_1983_To_WGS_1984_southern_California_54 1750
The code should be simple:
// 1. Prepare transformation:
SpatialReference spCaliforniaNAD = new SpatialReference(2229);
GeographicTransformationStep geoStep = new GeographicTransformationStep(1750);
GeographicTransformation geoTransform = new GeographicTransformation(geoStep);
// 2. Transform myPoint into projected coordinate system:
MapPoint myPoint = new MapPoint(-117.82739800, 34.64073000, SpatialReferences.Wgs84);
MapPoint projectedPoint = (MapPoint)GeometryEngine.Project(myPoint, spCaliforniaNAD, geoTransform);
The problem is that both GeographicTransformationStep and GeographicTransformation have missing projection engine files (IsMissingProjectionEngineFiles==true). Of course it results with exception in the last line.
How can I get that missing projection engine file?
Waldek
MichaelBranscomb
Esri Frequent Contributor
Additional information on this file is included in Spatial references—ArcGIS Runtime SDK for .NET | ArcGIS for Developers.
Thanks
Mike
MichaelBranscomb
Thanks
Mike
WaldemarNowak
After following the documentation you indicated I was able to download Projection Engine Data Files and indicated them for transformation. It works.
Thank you.
