Polylines in a shapefile
1587
08-03-2020 11:20 PM
OleJuul1
In Version 10.2.7 when you clicked on a polyline loaded from a shapefile you could set the property 'IsSelected' to true in the Graphic object and it will draw a line around itself. After upgrading to Version 100.7 the property is no longer there and I can not find a replacement.
OleJuul1
Thanks for the answer - it now works perfectly.
