Performance problems with Freehand sketch (using SketchEditor .NET)
857
03-08-2019 10:36 AM
StefanWeihs
Performance problems with Freehand sketch (using SketchEditor .NET😞
  • if you're drawing fast (direction is changed quickly), the path of the “sketch-line” doesn't follow the pens movement. (Display does not register pen position so fast)
  • The performance is worse with a finger than with a pencil.
  • Happens on Panasonic FZ-G1 and Surface Pro 4 i7 with ArcGIS Runtime .NET (100.4) and Windows 10.
only Workaround Right now is to draw really slowly 😐
Concerning Android SDK
SketchEditor gets started in MAinThread: OK
Not started in MainThread: slow down (starting after 5-7s only). Crashes with deleting a vertex
