Panning map using Surface Pro Pen
4351
07-30-2015 08:33 AM
JohnSelkirk
Is anyone having issues with panning the map using the pen on a Surface Pro?
Using my finger works just fine but when I try to use the Pen it does not respond
The same happens on a Motion Computing device so it is not Surface Pro specific.
John.
AnttiKajanus1
We disable panning by default using stylus. To enable panning with stylus you need to set PanOptions.IsStylusEnabled Property  to true in MapView.InteractionOptions Property
AnttiKajanus1
JohnSelkirk
Worked like a charm. Thanks!
