Pan using middle mouse button
1646
02-09-2022 05:12 AM
TimScheiber
I'm looking for a way to pan using the middle mouse button. In ArcMap you can pan around the map while being in a selection mode and I want the same behavior in my WPF application.
I have found a few other questions that ask the same thing, but are not really answered.
Is there any way to do this using the Runtime SDK for .NET?
dotMorten_esri
Esri Notable Contributor
How's this:
var peer = new Esri.ArcGISRuntime.UI.Controls.MapViewAutomationPeer(mapView);
Point? start = null;
mapView.MouseDown += (s, e) =>
    if (e.ChangedButton == MouseButton.Middle)
        start = e.GetPosition(mapView);
mapView.MouseUp += (s, e) =>
        start = null;
        peer.Complete();
mapView.PreviewMouseMove += (s, e) =>
    if (e.MiddleButton == MouseButtonState.Pressed && start.HasValue)
        var p = e.GetPosition(mapView);
            peer.Pan(p.X - start.Value.X, p.Y - start.Value.Y);
        start = p;
dotMorten_esri
How's this:
        start = null;
        peer.Complete();
        start = p;
