Ownership-based access control does not permit this operation on this feature. : The service does not have "create" capability.
4727
07-22-2015 12:02 PM
RonVincent
I'm trying to create a new point feature in a Runtime geodatabase but when my code gets to this line:
var recNo = await featureTable.AddAsync(newFeature);
I get the error in the title of this discussion:
Anyone else seen this and know how to resolve it? I'm running VS2013, Runtime 10.2.5.
Thanks!
AnttiKajanus1
It sounds like the user doesn't have permission to create new features to that service or service doesn't allow updates/creates.
  • Check that FeatureService that is used has necessary capabilities enabled
  • Check that user has permission to do so
  • Check that user is authenticated correctly
If these doesn't help, could you provide small reproducer?
Cheers,
Antti
JensBuchta
How did you create the Runtime Geodatabase?
If it was created by the export function in ArcMap, it's read-only.
You have to create the Geodatabase using the Tasks.Offline namespace in combination with ArcGIS Online / ArcGIS for Server.
AnttiKajanus1
Cheers,
Antti
RonVincent
I just found out that this data came from a Map Service, not a feature service which is the cause of the error.
