Optimised scale for distant points
1645
05-05-2022 07:52 AM
vergerk
Hello,
I have defined several remote points of interest on my 2D map and the scale is not appropriate.
Not wanting to put an arbitrary value in MainMapView.SetViewpointScaleAsync(value), is there a function to adapt the scale to display all the points present?
Or how is the scale calculated?
Thanks !
Sincerely
2 Solutions
KeithGanzenmuller
If your points are in a layer it's possible to set the ViewPoint to the Layer.FullExtent envelope
myMapView.SetViewpointAsync(new Viewpoint(YourLayerEnvelope));
 Of course you have to obtain the YourLayerEnvelope
Nicholas-Furness
If you have your point of interest geometries, you could also use GeometryEngine.combineExtents to get the minimal containing envelope. You can then pass that envelope to MapView.SetViewpointGeometryAsync() (that's a shortcut/equivalent to the method that Keith mentioned above).
KeithGanzenmuller
Nicholas-Furness
vergerk
Hello,
I had tried this approach by creating the envelope myself but nothing worked because I had not specified the spatial reference frame...
Thanks for your solutions, they are cleaner than the one I used 🙂
