OpenStreetMap Exceptions on zoom
1670
10-14-2020 01:58 AM
YaronAvraham
I'm using OpenStreetMap as a base map in 100.8 SDK with visual studio 2019,
when i'm doing fast zoom in or fast zoom out i'm getting alot of  "The request was aborted" web exception which are causing real slowdown when they are thrown.
any idea why i'm getting these exceptions?
Thanks
MichaelBranscomb
Esri Frequent Contributor
You will only see those exceptions when the debugger is attached. Try running without the debugger attached to see actual experience/performance.
Thanks
Mike
YaronAvraham
Hi, Thanks for the answer,
Yes i understand that i will see the exceptions only in debug mode, i do know that exception handling in .NET is quite expensive performance wise,
when i detach the debugger the performance is much better, but i can still sense some slowdown when i do fast zoom in/out,
any plans on fixing that in future releases?
