Opening an SLPK with Runtime 100.1 for WPF
1801
07-12-2017 12:41 PM
MichaelHamsa
Hello,
I've been working with previous versions of the 100.0 runtime based family (including the betas leading up to the latest release) and was having trouble opening a scene layer package. I just upgraded to 100.1 and attempted to open my test SLPK and was still having similar problems. I'm wondering if this version (100.1) supports opening SLPKs and if not when that is expected. As info, the scene layer package contains a LiDAR point cloud.
My code is pretty simple...
            var myScene = new Scene(Basemap.CreateStreets());
            var layer = new ArcGISSceneLayer();
            layer.Source = new Uri(@"file://C:/Public/LiDARDemonstration.slpk");
            myScene.OperationalLayers.Add(layer);
            scene.Scene = myScene;
Mike...
NagmaYasmin
Hi Mike,
Could you try to use the LoadAsync() method to load all the metadata before adding the scene layer on the scene.
Nagma
吴吴蔚
I have the same problem do you solve the problem?
