Offline Basemap Strategies (v100.0/WPF)
2228
04-14-2017 07:29 AM
KeithGemeinhart1
I'm looking for advice/guidance on strategies for offline basemaps.
After some investigation I've been able to generate a tile package (using Pro and Create Map Tile Package geoprocessing tool) using the tiled basemap services designed for export (http://www.arcgis.com/home/group.html?owner=esri&title=Tiled%20Basemaps&start=11&q). However, there seems to be a practical limit to both package generation time and size. 9 Levels for the whole world street map using 8-bit PNG took 68 minutes and 2.4Gb. Currently waiting for 10 levels to finish, but I'm guessing it will be > 4Gb.
Does anyone have data on how big a tile package for the whole world would be at each of the levels? I don't think we need all 20, but 14 might be good enough.
So questions about alternative approaches:
  • Is it possible to package or download the vector basemaps for offline use?
  • Has anyone generated a vector tile package (.vtpk) using the OSM data?
Are there any other offline basemap strategies or approaches that I haven't listed?
MichaelBranscomb
Esri Frequent Contributor
Each level is 4 times bigger than the previous. You can ask the server to estimate the size via the API: ExportTileCacheTask.EstimateTileCacheSize Method. For more info also see Plan a map cache—Documentation | ArcGIS Enterprise.
In a future release we plan to provide support for exporting vector tile caches. Vector tile caches provide significant benefits in terms of time taken to cache/export and size on disk.
Cheers
Mike
KeithGemeinhart1
Thanks Mike! Is exporting vector tile caches on the list for the next release or is it some yet-to-be-determined "future release?"
