No Identify-action when using magnifier on Android and IOS
1602
04-17-2025 02:05 AM
Labels (3)
MarkusLackinger
When using the "Magnifier" tool, no identify or zoom is performed after releasing. No event is triggered anywhere. I'm able to pan the map with magnifier. This behavior occurs on both Android and iOS.
Is it possible to use magnifier for zooming and identify? in QT-SDK was it 😉
I am using this code to activate magnifier.
myMapView.InteractionOptions = new MapViewInteractionOptions
IsEnabled = true
 Any ideas how to implement magnifier for identify? thanks.
MichaelDavis3
Hi Marcus - I don't think that's enough information for MapViewInteractionOptions to do what you want.  You probably need to be explicitly configuring items within it and passing a new MapViewInteractionOptions object with only IsEnabled = true might be unintentionally disabling a lot of functionality.
Maybe try something like
IsMagnifierEnabled = true
 And then make sure you have something in GeoViewTapped to actually do the identify:
https://developers.arcgis.com/net/api-reference/api/net/Maui/Esri.ArcGISRuntime.Maui.GeoView.GeoView...
dotMorten_esri
Esri Notable Contributor
I'm not quite following your expectations here, since identify operations aren't a built-in gesture.
Identify is a MapView operation you need to call in your custom code given an event, like for instance "tap".
MarkusLackinger
Hi everyone!
I probably didn't express myself clearly enough. Identifying features on the map when I tap it works perfectly. However, when the magnifier is already active and visible, and then lift my finger from the map, no GeoViewTabbed-event is triggered.
Here's a brief outline of my implementation:
myMapView.GeoViewTapped += MapTapped;
private async void MapTapped(object sender, GeoViewInputEventArgs e)
            Identify(e.Position);
private async void Identify(Point pos) {
      IReadOnlyList<IdentifyLayerResult> identifyResults = await myMapView.IdentifyLayersAsync(pos, 15, false);
dotMorten_esri
That's correct, since that isn't a tap-gesture (it's a hold + drag gesture)
MarkusLackinger
But for GeoView there is no hold+drag gesture.
Can this be done otherwise or will esri implement this event in future?
