.NET Map SDK High Cpu Usage
1301
02-04-2025 02:55 PM
Labels (4)
aburl1278
Hello, I am running the ESRI  ArcGISRuntime WPF (200.6.0)
I am running into an issue, with just a basic implementation of an ArcGISStreets basemap. Running in a release build x64 with no debugger attached, i can see CPU spikes of up to 80% when doing major pans or zooms. I have tested on various hardware and the CPU spikes vary. While I will note that the map performance stays smooth even with these brief CPU spikes, this does not seem normal to me.
Is there anything that can be done to mitigate these CPU spikes ?
dotMorten_esri
Esri Notable Contributor
The maps sdk will utilize all CPU cores to make things as performant and responsive as possible. If you pan and zoom a lot, a lot of tiles could be downloaded and processed which can create spikes (especially on a fast internet connection). This is normal. On a slower PC it is still smart enough to know that if you already panned past a tile that didn't get a chance to get processed, and it'll skip it and move on.
One thing to note though is to make sure you're not running in software rendering mode - that can often happen in remote desktop (except with .net9), WinForms embedding, or on some VMs or low-end GPUs and that'll put a lot more pressure on the CPU instead.
If you want the most performance possible, WinUI uses a newer DirectX technology than WPF and integrates much better with Windows' rendering stack and is therefore able to squeeze out more rendering performance with less resources (and also suffers much less from the software rendering fallbacks mentioned above).
SomeGISGuy
dotMorten_esri
aburl1278
Thank you, this makes sense. I was actually doing alot of my testing over RDC that would explain the software rendering performance.
