MapPoint.Project(...) to other spatial has insufficient accuracy (with 31256)
1332
02-13-2023 11:55 PM
SokoFromNZ
I have found a bug (?) in your projecting algorithmn which leads to a 200 meter error.
This line:
var wgs84 = (MapPoint) new MapPoint(-76819.429, 187725.102, SpatialReference.Create(31256) ).Project(SpatialReferences.Wgs84);
Calculates to:
{MapPoint[X=15.321529847554814, Y=46.82430179466435, Wkid=4326]}
 As I know what feature on the satellite map should be there I see this is off.
In addition using https://products.aspose.app/gis/en/transformation for the projection leads to the correct 4326 values of
15.32549716745482 46.82433872507569
As I'm a novice in all this geo spatial stuff I may be using it wrong. But I can't see where...
Thanks for your help in advance
dotMorten_esri
Esri Notable Contributor
Does this projection require datum grid transformation? If so, did you supply the projection engine with the data necessary? See https://developers.arcgis.com/net/spatial-and-data-analysis/spatial-references/#grid-based-transform...
dotMorten_esri
SokoFromNZ
Yeah... it seems I am missing the transformation for this projection.
Now with
var target = SpatialReference.Create(31256);
var transformation = TransformationCatalog.GetTransformation(target, SpatialReferences.Wgs84,
            new Envelope(data.Min(a => a.X), data.Min(a => a.Y), data.Max(a => a.X), data.Max(a => a.Y), target));
var wgs84 = (MapPoint) new MapPoint(x, y, target).Project(SpatialReferences.Wgs84, transformation);
it delivers the correct values.
