log an entry when parcel layer isn't indexed
902
08-21-2019 02:01 PM
ReemaPruthi
Hello,
I am trying to figure out a way to know if the parcel layer is indexed or not. Using the ESRI ArcGIS Runtime for .NET, is it possible to determine in code what attribute indexes exist for a FeatureTable? We are working on UWP.
Regards,
Reema
MichaelBranscomb
Esri Frequent Contributor
It looks like can access this information from the REST endpoint of the feature service layer but we do not currently expose it via an API property on ArcGISFeatureLayerInfo class.
You could make the request yourself using C# and the ArcGISHttpClientHandler (which will help handle any authentication required).
Cheers
Mike
