LocalServer won't start geoprocessing services
5692
11
02-20-2019 06:30 AM
EricaPfister
I have a .NET application with Local Server, and it starts and displays a map service from a map package. However, it cannot start the geoprocessing service I'm also trying to include. I've tried with the gpk that I actually need, a gpk with a simple Buffer operation (just for testing purposes), and a gpkx with a simple Buffer operation. All are giving the same error:
Failed to create service examplemodel GPServer. Worker process 'examplemodel_host' exited while attempting to service request (attempt 1 of 1): endpoint='admin' headers={} params={asynchronous=, filePath=c:\temp\examplemodel.gpk, jobDir=C:\Users\[.....]\AppData\Local\Temp\1\arcgisruntime_19956\examplemodel\jobs, maxRecords=1000, name=examplemodel, outputDir=C:\Users\[.....]\AppData\Local\Temp\1\arcgisruntime_19956\examplemodel, type=GPServer, virtualDir=http://127.0.0.1:50000/5rc2jC/outputdir/examplemodel} res='create' post=0 Crash dump path=C:\Users\[.....]\AppData\Local\Temp\1\ArcGISRuntimeErrorReports\arcgisruntime_100.3.0.2102_service_20190219_194809.dmp
I did check the ArcGISLocalServer_100.3.AGSDeployment file, and changed the Geoprocessing lines:
      <Package id="ProGeoProcessing" name="Geoprocessing" enabled="true">
      <Package id="ArcMapGeoprocessing" name="Geoprocessing" enabled="true">
Unfortunately, I'm still getting the same error. What else do I need to fix?
Sharan_saiGudibanda_Nagesh
Yeah but no log is recorded in utility
Get Outlook for Android<https://aka.ms/ghei36>
I have tried the local server in another system, which doesn't have any ArcGIS software, There the application has succeded, But in my system it's not processing. Do you have any solution to resolve this issue?
Regards
G N Sharan Sai
