Local MBTiles ( C# Universal Windows Platform Application)
4943
01-19-2016 11:53 PM
steelissteelis
May I know if it is possible to load a Local MBTiles file into the Dotnet Universal Windows Platform? So far, the only example I have managed to find is for Android API.
Any help and preferably with example is greatly appreciated.
Thanks and Regards,
Steelis2013
ScottBrady1
Was this answered, as I am having similar issues only with a WPF application.
MichaelBranscomb
Esri Frequent Contributor
It should be possible. But we're currently investigating an issue with the tile request call backs for custom layers deriving from `ImageTiledLayer`. If possible, we intend to resolve that in a release later this year.
Cheers
Mike
OscarDiago_Alonso
Is it possible then to use a MBTILES in the latest version of the ArcGIS Runtime for .NET?
The documentation doesn't mention it:
ArcGIS Runtime supports the following offline layers
  • Tiled layer data stored in tile packages (.tpk or .tpkx).
  • Vector tiled layer data stored in vector tile packages (.vtpk).
  • Feature layer data stored in the following formats:
    • ArcGIS features held in a mobile geodatabases (.geodatabase).
    • Features stored in a GeoPackages provisioned by the OGC file format (.gpkg).
    • Features stored in the Shapefile format provided by the .shp file and its associated files (.dbf, .shx, etc).
  • Raster layer data stored in a raster dataset file or in a GeoPackage (.gpkg).
Could you share any code sample to show how to use a MBTILES file with the ArcGIS Runtime, please?
Thanks!
