Loading raster throws Unlicensed feature exception
2100
10-09-2023 01:34 AM
TomGreenDk
Running on Android with xamarin.forms through .net IDE.
When trying to load a geoTiff file from resources, I get "unlicensed feature" on loading. This seems to indicate that... I dont have a valid license for that, though I have a lite account now (testing the usability of mapping framework still) and do not have the "developer license watermark" any longer.
Should Raster layers not work for this?
What I am doing is simply
Raster raster = new Raster(imagePath);
await raster.LoadAsync(); -> exception
MichaelBranscomb
Esri Frequent Contributor
Local raster data sources require a Standard level license - for more information see License levels and capabilities | ArcGIS Maps SDK for .NET | ArcGIS Developers.
Note raster doesn't have quite the same simple local/remote concept as KML but image services are available with ArcGIS Enterprise and ArcGIS Online.
For more info see:
Host imagery using ArcGIS Image for ArcGIS Online—Imagery Workflows | Documentation
What is an image service?—ArcGIS Image Server | Documentation for ArcGIS Enterprise
DanPatterson
MVP Esteemed Contributor
perhaps related albeit for a different data source
Solved: Viewing KML from websource says "unlicensed featur... - Esri Community
... sort of retired...
TomGreenDk
That seems likely, thanks. I will see if I can get away with getting it online and not local to duplicate that workaround.
MichaelBranscomb
For more info see:
