load a GIS file
2183
10-25-2016 12:25 PM
JinHao
Hi There,
We have GIS files on our local computer,  I wonder does the current ArcGIS API support me to load the GIS files onto a GIS map component and then let me do editing?
J
Tags (1)
MichaelBranscomb
Esri Frequent Contributor
Most likely yes, but it does depend what format those files are in. Please can you list the file formats you have?
Cheers
Mike
JinHao
Hi Mike,
Thanks for the reply.
The file I am going to load from my local is:  dbf, prj
Can you let me know which GIS .net API function do the load ?
I checked the Guid at here: Developer's guide—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
I don't see any of the function says it can load a file.
Jin
JinHao
Here is a list of file format that I want the API to load:
dbf,  def, prj, shp, shx
NeilAyres
Those are the components of a shapefile.
