Legend for DynamicLayer
4106
8
01-28-2016 05:16 AM
BrianFoley1
am trying to create a multi-layer legend for an ArcGISDynamicMapServiceLayer.  I want to be able click on an arrow to drop down to the next level.  The second level has several levels below that, and I also want to be able to click on an arrow to show the final sub-layer.  Now, I'm able to do this, however, on the last sub-layer, I want to show the color and displayname associated with that sub-layer.  This is what my  code looks like :
I can't get the color for the sub-layer to show using <image> tag.  Can anyone provide some help.  Thanks.
Brian
<esri:Legend.LegendItemTemplate>
    <DataTemplate>
       <Button Visibility="Collapsed" Tag="{Binding Label}">
           <Grid>
               <Grid.ColumnDefinitions>
                   <ColumnDefinition/>
                   <ColumnDefinition/>
               </Grid.ColumnDefinitions>
               <Image Grid.Column="0" Source="{Binding ImageSource}" />
               <TextBlock Grid.Column="1" Text="{Binding Label}" />
            </Grid>
       </Button>
    </DataTemplate>
</esri:Legend.LegendItemTemplate>
AndreaWeeg
how are you setting the ImageSource? if its just a hex color why don't you use a rectangle and fill it with the color instead of using an image control?
BrianFoley1
Andrea, I didn't know I had to set the imagesource.  How would I do that ?
AndreaWeeg
you have to look at the data source, i can't tell from your code what you are binding to..can you share that part of the code?
BrianFoley1
Andrea,  the data source is coming from an ArcGISDynamicMapServiceLayer.
BrianFoley1
Andrea,
            It might be better if I send you some code and pictures to better explain what I’m trying to do.  Should I send it to this email or do you have a private email I can send it to ?  Thanks.
Brian
AndreaWeeg
this email is good. i think is the sublayers that are messing you up but shouldn't be too hard to figure it out
BrianFoley1
Andrea, do you have a private email I send my code to ? I don’t feel comfortable putting my code on the forum because one of the ServiceURI links is private and shouldn’t be seen by everyone on the forum.
--Brian
AndreaWeeg
