It will be updated the ESRI ArcGisRuntime for .NET to XAML Standard 1.0 and how fast?
1230
07-05-2017 09:29 AM
marceloctorres
In the last Microsoft Build 2017 that took place in May of this year, Microsoft announced the unification of the different XAML dialects used in various technologies such as Xamarin.Forms, UWP and WPF under the XAML Standard 1.0. The Esri ArcGISRuntime for .NET and specifically the APIS for WPF, UWP and Xamarin.Forms are expected to meet this standard?
Marcelo César Torres
MichaelBranscomb
Esri Frequent Contributor
The new XAML Standard is a really exciting development for us as developers working with WPF, UWP, and Xamarin. We are monitoring the development of the standard very closely to determine when it provides sufficient functionality and platform support that would make it possible to transition the APIs included within ArcGIS Runtime SDK for .NET over to the standard. We also need to consider what that transition would mean for users building apps today with our API (upgrade experience, breaking changes, etc).
Cheers
Mike
dotMorten_esri
Esri Notable Contributor
The goals of the standard are quite vague, however it doesn't seem to have any effect on the ArcGIS Runtime what-so-ever, since its goal is merely to create a standard set of vocabulary among the different XAML flavors when interpreting the XAML (like a TextBlock is called a TextBlock and not a Label, although under the covers it's still a Label). As such this won't really have any effect on the runtime. Also we already use a standard vocabulary so in a way we are a little bit ahead of the standard (ie it's always called a MapView, and it always has a Map property etc on all the platforms we support).
There wouldn't be any changes required on our part - it'll just come to you for free.
Having said that, I'm personally taking an active role in helping to shape the direction of the standard to ensure it'll fit the needs of our customers and the pain points they are dealing with. I'd encourage you to do the same, as the standard is being developed in the open.
