Is there a method to draw an arc?
2440
01-03-2018 02:42 PM
BikeshMaharjan1
Like creating an Ellipse or Polygon, Is there any method to draw an arc?
Thanks!
dotMorten_esri
Esri Notable Contributor
Creating curves programmatically are not supported at this point.
You can approximate arcs manually with a bit of trigonometry, or you can use the GeometryEngine methods to create various forms of ellipses and arcs (I don't know your scenario, but these methods might be what you're really looking for - or not at all):
  • GeometryEngine.EllipseGeodesic
  • GeometryEngine.Buffer
  • GeometryEngine.BufferGeodesic
  • GeometryEngine.SectorGeodesic
  • GeometryEngine.DensifyGeodetic
See doc here:
https://developers.arcgis.com/net/latest/wpf/api-reference//html/T_Esri_ArcGISRuntime_Geometry_Geome...
BikeshMaharjan1
Hi Morten,
Thank you for the information. I want to create arcs to make an arc circuit with 4 arcs, similar to bow tie with arcs.
In the Geometry Engine, I did not see any methods to create just arcs like you mentioned. Is there any?
Bikesh
dotMorten_esri
As mentioned no there's no such methods. I listed a set of methods that generates curve-like geometries, in case that was what you were really looking for.
I don't understand what you mean by arc circuits and bow ties. In any case, you'd have to calculate the vertices along the arc yourself to make a polyline that looks curved.
