Is the GraphicCollection class thread safe?
1325
06-05-2024 11:14 AM
Mike_Quetel
API docs don't explicitly say, but is the GraphicCollection class thread safe?  Use case is that I have a large(ish) number of graphics (25,000 to maybe 100,000)  to add to an overlay.  Can this task be safely chunked into batches and run in parallel?
MatveiStefarov
The GraphicCollection class is indeed thread-safe (synchronized).  However, the most efficient way to populate it would be to use AddRange method (optimized to reduce temporary allocations and locking/unlocking/eventing overhead).  So, yes, you can absolutely parallelize creation of your Graphic objects -- e.g. using Parallel.ForEach with a partitioner -- but I suggest adding Graphics to the collection in batches of several hundred/thousand rather than individually.
We actually have a whole guide topic dedicated to Graphic performance, check it out for more tips: Performance considerations | ArcGIS Maps SDK for .NET | ArcGIS Developers
A couple years ago we also talked about performance for Graphic-heavy apps at DevSummit.  You can find a recording of it here: "ArcGIS Runtime SDK for .NET: Building Apps - Part 2" (relevant part starts around the 25-minute mark).
MatveiStefarov
Mike_Quetel
Thank you, this is all very useful.  🍻
