[iOS] NullReferenceException in Geolocator.LocationManager_LocationsUpdated
3999
06-19-2024 03:35 PM
esp1rl
We get these errors reported through Sentry.
It's very important to note that these always happen at startup.
System.NullReferenceException: Object reference not set to an instance of an object
  ?, in void Geolocator.LocationManager_LocationsUpdated(object sender, CLLocationsUpdatedEventArgs e)
  ?, in void _CLLocationManagerDelegate.LocationsUpdated(CLLocationManager, CLLocation[])
  ?, in int UIApplicaion.UIApplicationMain(int, string[], IntPtr, IntPtr)
  ?, in void UIApplication.Main(string[], Type, Type)
  ?, in void Program.Main(string[] args)
OS Version: iOS 17.5.1 (21F90)
Report Version: 104
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: SEGV_NOOP at 0x0000000000000050
Crashed Thread: 0
Application Specific Information:
Exception 1, Code 1, Subcode 80 >
KERN_INVALID_ADDRESS at 0x50.
Thread 0 Crashed:
0   Naturoppdrag                    0x2021afde8         Esri_ArcGISRuntime_Esri_ArcGISRuntime_Internal_Geolocator_LocationManager_LocationsUpdated_object_CoreLocation_CLLocationsUpdatedEventArgs
1   Naturoppdrag                    0x205ded368         mono_jit_runtime_invoke (mini-runtime.c:3636)
2   Naturoppdrag                    0x205d99fbc         [inlined] do_runtime_invoke (object.c:2576)
3   Naturoppdrag                    0x205d99fbc         mono_runtime_try_invoke (object.c:2733)
4   Naturoppdrag                    0x205d9ccdc         mono_runtime_invoke (object.c:2659)
5   Naturoppdrag                    0x205e9c8f4         native_to_managed_trampoline_117 (registrar.mm:7322)
6   Naturoppdrag                    0x205ea2840         -[CoreLocation_CLLocationManager__CLLocationManagerDelegate locationManager:didUpdateLocations:] (registrar.mm:29700)
7   CoreLocation                    0x3327ff958         CLCopyTechnologiesInUse
8   CoreLocation                    0x3327ff0ec         CLCopyTechnologiesInUse
9   CoreLocation                    0x3327feed8         CLCopyTechnologiesInUse
10  LocationSupport                 0x356ff8d50         CLConnectionMessage::createXPCObject
11  CoreFoundation                  0x31840fc98         __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__
12  CoreFoundation                  0x3183fdde8         __CFRunLoopDoBlocks
13  CoreFoundation                  0x3183fdacc         __CFRunLoopRun
14  CoreFoundation                  0x3183fccd4         CFRunLoopRunSpecific
15  GraphicsServices                0x3a21af1a4         GSEventRunModal
16  UIKitCore                       0x31ccb6908         -[UIApplication _run]
17  UIKitCore                       0x31cd6a9cc         UIApplicationMain
18  Naturoppdrag                    0x205b51a4c         xamarin_UIApplicationMain (bindings.m:126)
19  Naturoppdrag                    0x201ca4b5c         wrapper_managed_to_native_UIKit_UIApplication_xamarin_UIApplicationMain_int_intptr_intptr_intptr_intptr_
20  Naturoppdrag                    0x205a6a410         Microsoft_iOS_UIKit_UIApplication_UIApplicationMain_int_string___intptr_intptr (UIApplication.cs:58)
21  Naturoppdrag                    0x205ded368         mono_jit_runtime_invoke (mini-runtime.c:3636)
22  Naturoppdrag                    0x205d990a8         [inlined] do_runtime_invoke (object.c:2576)
23  Naturoppdrag                    0x205d990a8         mono_runtime_invoke_checked (object.c:2792)
24  Naturoppdrag                    0x205d9f0ec         [inlined] do_exec_main_checked
25  Naturoppdrag                    0x205d9f0ec         mono_runtime_exec_main_checked (object.c:4775)
26  Naturoppdrag                    0x205df2718         [inlined] mono_jit_exec_internal (driver.c:1369)
27  Naturoppdrag                    0x205df2718         mono_jit_exec (driver.c:1314)
28  Naturoppdrag                    0x205b5caf8         xamarin_main (monotouch-main.m:495)
29  Naturoppdrag                    0x205e5afe0         main (main.arm64.mm:352)
30  <unknown>                       0x1b38e5e4c         <redacted>
dotMorten_esri
Esri Notable Contributor
Thank you for the detailed callstack. We have a speculative but safe fix we'll add, and hopefully that'll take care of this one (can't really verify without a reproducer and it seems to require a very particular case of location update firing right when the datasource is created).
dotMorten_esri
esp1rl
Thanks @dotMorten_esri
PreetiMaske
Good news!  ArcGIS Maps SDK version 200.5.0 was just released today and the speculative fix is available with this release. Please try the latest version and let us know if the issue is fixed for you.
Thank you for bringing this one to our attention!
