iOS 13 and Runtime versions
2306
10-17-2019 12:49 PM
EricBader2
Hey there,
Now that iOS 13.x is out, is there any information out there anywhere about which versions of ArcGIS Runtime SDK for .NET (Xamarin Forms) are supposed to work with it? The old system requirements seem to only mention minimum version.
Thanks!
EB
MichaelBranscomb
Esri Frequent Contributor
Eric,
ArcGIS Runtime SDK for .NET 100.6 is supported on iOS 11 and 12. We plan to list support for iOS 13 with the upcoming 100.7 release. Initial testing of iOS 13 did not indicate any major issues but we do expect to make some changes to accommodate for the new Dark Mode and for changes in iOS location privacy behavior.
Regards
Mike
MichaelBranscomb
Eric,
Regards
Mike
EricBader2
Hi Mike,
So is it fair to assume that, today, ArcGIS Runtime SDK for .NET v100.4 is not officially supported on iOS 13.5.1 devices? Since support for iOS 13 was official at 100.7? I'm typically referred to as "Captain Obvious", so I can hear the laughs already!
EB
MichaelBranscomb
Hi Eric,
Version 100.4 is in the `Extended Support` phase which means it does not undergo certification for new environments and therefore it hasn't been formally tested and certified for use with iOS 13.5.1. We're not currently aware of any issues that may arise from using v100.4 with iOS 13.5.1.
Thanks
Mike
EricBader2
Right on, Sir. Thank you.
