Implementing app authentication with client secret in Runtime SDK 200.7
1878
7
09-22-2025 06:03 PM
azlotin
I have the following working Runtime SDK 100.x code implements application authentication:
ServerInfo serverInfo = new ServerInfo
ServerUri = new Uri(SERVER_URL),
TokenAuthenticationType = TokenAuthenticationType.OAuthClientCredentials,
OAuthClientInfo = new OAuthClientInfo { ClientId = CLIENT_ID, ClientSecret = CLIENT_SECRET, RedirectUri = new Uri(REDIRECT_URL) }
AuthenticationManager.Current.RegisterServer(serverInfo);
AuthenticationManager.Current.OAuthAuthorizeHandler = new OAuthAuthorize();
AuthenticationManager.Current.ChallengeHandler = new ChallengeHandler(CreateCredentialAsync);
As OAuthClientInfo is obsolete at 200.7, I have rewritten this as:
ServerInfo serverInfo = new ServerInfo(new Uri(SERVER_URL))
var userConfig = new OAuthUserConfiguration(new Uri(SERVER_URL), CLIENT_ID, new Uri(REDIRECT_URL));
AuthenticationManager.Current.OAuthUserConfigurations.Add(userConfig);
How do I include Client Secret here so the users are not getting the authentication prompt? I understand I should be using OAuthApplicationCredential, but I cannot figure out how.
Thanks!
dotMorten_esri
Esri Notable Contributor
To add to Preeti's answer, ALL of the above code can be replaced with
AuthenticationManager.Current.AddCredential(await OAuthApplicationCredential.CreateAsync(SERVER_URL, CLIENT_ID, CLIENT_SECRET));
When using an app credential added up front, there's no need for messing with server infos, oauth configs, credential callbacks etc. Just the above line before accessing your server.
PreetiMaske
Here is the detailed blog post that explain usage of new auth APIs and how to best use them
https://www.esri.com/arcgis-blog/products/sdk-net/developers/new-auth-apis-for-dotnet-sdk
Please give this a read, especially `Configuring OAuth` section that particularly talks about OAuth. For OAuth app authentication, pass client ID and client secret directly to OAuthApplicationCredential.CreateAsync.
Hope this helps,
dotMorten_esri
azlotin
Thank you both for the prompt answers!
azlotin
Hi Morten,
I spoke too soon back in September. The single line of code you suggested does not appear to work. The line executes without any errors, but the map remains empty, with no layers loaded. This is the behavior when debugging in Visual Studio. If the application is deployed to another machine using an installer, the map is not loaded either and the application crashes a few seconds later.
The lengthy version of the code in my original post does not throw any errors but brings up the portal login prompt.
Any ideas? Thanks.
dotMorten_esri
When you say they don't load, what load errors do you see? (observe the errors coming from LoadAsync, or just look in the debug output window where load errors should also be written)
azlotin
Thanks Morten, there are indeed errors in the Output window (see below). Not sure what this means. Do Client Id and Client Secret need to be updated? They are the same as in the original 100.x application.
Accessing https://basemapstyles-api.arcgis.com requires authorization. Set a ChallengeHandler to provide credentials. For more information see https://developers.arcgis.com/net/security-and-authentication/
ArcGIS Maps SDK: Load Error: Basemap
Esri.ArcGISRuntime.Http.ArcGISWebException
Token Required.
The required authentication information is missing. Unable to authorize access without a valid token.
ArcGIS Maps SDK: Load Error: Map
Token Required.
dotMorten_esri
Did you set the API Key? You either need to sign into ArcGIS Online first, or set an API key to access the new basemap services. See https://developers.arcgis.com/net/security-and-authentication/tutorials/implement-api-key-authentica...
