IdentifyGraphicsOverlaysAsync problem
938
06-07-2019 03:13 AM
GonzaloMuöoz
I'm using IdentifyGraphicsOverlaysAsync to detect a graphic from the map with the latitude and longitude of the element, the exact latitude and longitude. The problem es that this method not always returns the appropiate graphic and it returns others that are close. I've test many method usages but none of them returns only the graphic. Only if I put a big number of results it works, but I only want one graphic result, the one int the position.
Why is this method not working and how can I make it work appropiately?
