How to remove selection behavior from the map legend layers
1316
08-09-2019 01:37 PM
ReemaPruthi
Hello dotMorten,
I have been googling a lot about this issue and ended up creating a ticket here for any sort of help that I can get. I wish to remove the selection behavior altogether (via mouse and tap) from the map legend layers. I don't want any kind of selections possible in there. If that is not possible, I would atleast want to know how to set the selection color to white/transparent??
Regards,
Reema
ReemaPruthi
This is an urgent issue. Can someone please help?
MichaelBranscomb
Esri Frequent Contributor
Have you tried Morten's suggestion on the Toolkit issue you opened?
...look at the control templates used. It's probably a setting on the listview control that you can set by overriding the control template.
The following links should help you get started:
Item containers and templates - Windows UWP applications | Microsoft Docs
Disabling selection of some items in a UWP ListView | Magnus Montin
Cheers
Mike
