How to Perform Raster Mosaic using ArcGIS Run time
2112
02-22-2018 10:14 PM
Siva_SankaraReddy_T
Hi Everyone,
Is there any possibility to perform Raster(dtd 2) Mosaic  using ArcGIS Run time Application. I have dtd2 files so need to Mosaic into one file for Analysis.
Tags (1)
dotMorten_esri
Esri Notable Contributor
Look at the MosaicDatasetRaster class and its Create Method
MosaicDatasetRaster.Create Method (String, String, SpatialReference)
After creation you'd then use the AddRastersAsync method:
MosaicDatasetRaster.AddRastersAsync Method
KeithGemeinhart1
In case you are still looking for a solution, you can accomplish this by building a geoprocessing model in ArcMap or Pro and then creating a gpk for use in Runtime.
dotMorten_esri
KeithGemeinhart1
Cool! I didn't know that existed in the runtime itself.
