How to make geodatabase editable property as true ?
1840
04-25-2018 06:17 AM
VijitWadhwa
I tried to run the sample of editing the geodatabase offline , which adds the birds and marine features offline
Geodatabase transactions—ArcGIS Runtime SDK for .NET Samples | ArcGIS for Developers
But when i created a geodatabase from ArcGIS Desktop(ArcMap) , it does not allow me to add Feature, How can i solve this and make my .geodatabase editable ??
Michael BranscombAntti Kajanus Morten Nielsen
dotMorten_esri
Esri Notable Contributor
Geodatabases created with Pro are not editable. You'll need to use a sync-enabled feature service and generate the database that way for it to be editable.
VijitWadhwa
Sir I am working on a project for disconnected environment , what is the
other way of doing it offline . If I don't want to use feature layer
service with sync enabled , how can I do it sir ? Please help me with some
alternative way sir
dotMorten_esri
That's the only way at this point. If you want to edit the geodatabase, the story is having a sync-enabled database created from the feature service.
VijitWadhwa
Is editing possible with file geodatabase using local server ?
