how to get MapView in ViewModel Using MVVM
18523
16
05-31-2017 04:07 AM
NadirHussain
Dear All,
i am using mvvm technique.my model class is given below.
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="*" />
<RowDefinition Height="auto" />
</Grid.RowDefinitions>
<Grid Grid.Row="0" RowSpacing="0" ColumnSpacing="0" BackgroundColor="Transparent">
<esriUI:MapView x:Name="MyMapView" Map="{Binding myMap}" BackgroundColor="GreenYellow" />
</Grid>
<Grid Grid.Row="1" RowSpacing="0" ColumnSpacing="0" BackgroundColor="Transparent">
    <Button Text="Direction" BackgroundColor="Black" TextColor="White" Command="{Binding Hello}" />
</Grid>
</Grid>
On my button click i want to ACCESS MyMapView in my model in modelview class.I cant under stand how i get the reference of this MyMapView  on event in modelview.because on click event i want to add some graphics on my map.
please help.Thanks in advance.
please help.
Thanks in advance
NadirHussain
Dear Marcelo,
Actually i want to calculate the distance from start to end point.and draw route.When draw route it should zoom to that route.i cant zoom to that path.
Thanks in advance.I am waiting for the sample code.
NagmaYasmin
Hi Nadir,
I assumed you already created the route and would like to zoom to the extent of that route. Below is the code that zooms to that extent:
 await MyMapView.SetViewpointAsync(new Viewpoint(route.Extent));
Hope that helps.
Nagma
marceloctorres
I'm back. Here I'll explain the solution that I made to WPF now to Xamarin.Forms. First, no implement MVVM pattern easly I used nuget package Prism.Forms from Brian Lagunas. I made the ViewModel class in C# and the View code using XAML in a similar way that in the WPF Project:
This is the ViewModel code:
using Esri.ArcGISRuntime.Geometry;
using Esri.ArcGISRuntime.Mapping;
using Esri.ArcGISRuntime.Symbology;
using Esri.ArcGISRuntime.UI;
using Prism.Commands;
using Prism.Mvvm;
using System.Windows.Input;
#if WINDOWS_UWP
using Colors = Windows.UI.Colors;
#else
using Colors = System.Drawing.Color;
#endif
namespace GeonetPost.Xamarin.ViewModels
  public class MapPageViewModel : BindableBase
    private Map _myMap;
    /// <summary>
    /// </summary>
    public Map MyMap
      get { return _myMap; }
      set { SetProperty(ref _myMap, value); }
    private GraphicsOverlayCollection _grapchicsOverlays;
    /// <summary>
    /// </summary>
    public GraphicsOverlayCollection GraphicsOverlays
      get { return _grapchicsOverlays; }
      set { SetProperty(ref _grapchicsOverlays, value); }
    private Viewpoint _viewpoint;
    /// <summary>
    /// </summary>
    public Viewpoint Viewpoint
      get { return _viewpoint; }
      set { SetProperty(ref _viewpoint, value); }
    private Viewpoint _updatedViewpoint;
    /// <summary>
    /// </summary>
    public Viewpoint UpdatedViewpoint
      get { return _updatedViewpoint; }
      set { SetProperty(ref _updatedViewpoint, value); }
    /// <summary>
    /// </summary>
    public ICommand ButtonClickCommand { get; private set; }
    /// <summary>
    /// </summary>
    public ICommand ZoomCommand { get; private set; }
    /// <summary>
    /// </summary>
    public ICommand UpdateViewpointCommand { get; private set; }
    /// <summary>
    /// </summary>
    public MapPageViewModel()
      MyMap = new Map(Basemap.CreateStreets());
      GraphicsOverlays = new GraphicsOverlayCollection();
      ButtonClickCommand = new DelegateCommand(ButtonClickAction);
      ZoomCommand = new DelegateCommand(ZoomAction);
      UpdateViewpointCommand = new DelegateCommand<Viewpoint>(UpdateViewpointAction);
      GraphicsOverlay go = new GraphicsOverlay()
        Id = "MyGraphicOverlay"
      GraphicsOverlays.Add(go);
    /// <summary>
    /// </summary>
    private void ButtonClickAction()
      var g = new Graphic()
        Geometry = new MapPoint(-74, 4, SpatialReferences.Wgs84),
        Symbol = new SimpleMarkerSymbol() { Color = Colors.Green, Style = SimpleMarkerSymbolStyle.Circle, Size = 10 }
      GraphicsOverlays[0].Graphics.Clear();
      GraphicsOverlays[0].Graphics.Add(g);
    /// <summary>
    /// </summary>
    private void ZoomAction()
      Viewpoint = new Viewpoint(4, -74, 5000000);
    /// <summary>
    /// </summary>
    /// <param name="vp"></param>
    private void UpdateViewpointAction(Viewpoint vp)
      var projectedVp = new Viewpoint(GeometryEngine.Project(vp.TargetGeometry, SpatialReferences.Wgs84), vp.Camera);
      if (UpdatedViewpoint == null || projectedVp.ToJson() != UpdatedViewpoint.ToJson())
        UpdatedViewpoint = projectedVp;
This is the View code:
<?xml version="1.0" encoding="utf-8" ?>
<ContentPage xmlns="http://xamarin.com/schemas/2014/forms"
             xmlns:x="http://schemas.microsoft.com/winfx/2009/xaml"
             xmlns:prism="clr-namespace:Prism.Mvvm;assembly=Prism.Forms"
             xmlns:bh="clr-namespace:GeonetPost.Xamarin.Behaviors"
             xmlns:cv="clr-namespace:GeonetPost.Xamarin.Converters"
             xmlns:esri="clr-namespace:Esri.ArcGISRuntime.Xamarin.Forms;assembly=Esri.ArcGISRuntime.Xamarin.Forms"
             prism:ViewModelLocator.AutowireViewModel="True"
             x:Class="GeonetPost.Xamarin.Views.MapPage">
  <ContentPage.Resources>
    <ResourceDictionary>
      <cv:GeographicCoordinateConverter x:Key="GeoCoorConverter" />
    </ResourceDictionary>
  </ContentPage.Resources>
  <Grid>
    <esri:MapView Map="{Binding MyMap}"
                  GraphicsOverlays="{Binding GraphicsOverlays}">
      <esri:MapView.Behaviors>
        <bh:SetMapViewViewportBehavior Viewpoint="{Binding Viewpoint}" />
        <bh:MapViewViewpointChangedBehavior Command="{Binding UpdateViewpointCommand}" />
      </esri:MapView.Behaviors>
    </esri:MapView>
    <Grid Margin="10"
          HorizontalOptions="Start"
          VerticalOptions="Start"
          BackgroundColor="Beige">
      <StackLayout Orientation="Vertical"
                   Margin="10"
                   HeightRequest="100">
        <Label Text="{Binding UpdatedViewpoint.TargetGeometry.XMin, Converter={StaticResource GeoCoorConverter}, ConverterParameter='X', StringFormat='XMin = {0}'}" />
        <Label Text="{Binding UpdatedViewpoint.TargetGeometry.YMin, Converter={StaticResource GeoCoorConverter}, ConverterParameter='Y', StringFormat='YMin = {0}'}" />
        <Label Text="{Binding UpdatedViewpoint.TargetGeometry.XMax, Converter={StaticResource GeoCoorConverter}, ConverterParameter='X', StringFormat='XMax = {0}'}" />
        <Label Text="{Binding UpdatedViewpoint.TargetGeometry.YMax, Converter={StaticResource GeoCoorConverter}, ConverterParameter='Y', StringFormat='YMax = {0}'}" />
      </StackLayout>
    </Grid>
    <StackLayout Grid.Row="1"
                 Orientation="Horizontal">
      <Button Margin="5"
              Text="Click me!"
              WidthRequest="150"
              TextColor="White"
              Command="{Binding ButtonClickCommand}" />
      <Button Margin="5"
              Text="Zoom to Point"
              WidthRequest="150"
              TextColor="White"
              Command="{Binding ZoomCommand}" />
    </StackLayout>
  </Grid>
</ContentPage>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
And this is the code of the SetMapViewViewportBehavior:
using Esri.ArcGISRuntime.Xamarin.Forms;
using System.Diagnostics;
using System.Runtime.CompilerServices;
using Xamarin.Forms;
namespace GeonetPost.Xamarin.Behaviors
  public class SetMapViewViewportBehavior : BehaviorBase<MapView>
    /// <summary>
    /// </summary>
    public static readonly BindableProperty ViewpointProperty =
      BindableProperty.Create(nameof(Viewpoint), typeof(Viewpoint), typeof(SetMapViewViewportBehavior));
    /// <summary>
    /// </summary>
      get { return (Viewpoint)GetValue(ViewpointProperty); }
      set { SetValue(ViewpointProperty, value); }
    /// <summary>
    /// </summary>
    public SetMapViewViewportBehavior()
    /// <summary>
    /// </summary>
    /// <param name="propertyName"></param>
    protected override void OnPropertyChanged([CallerMemberName] string propertyName = null)
      base.OnPropertyChanged(propertyName);
      if (propertyName == nameof(this.Viewpoint))
        SetViewpoint(this.Viewpoint);
    /// <summary>
    /// </summary>
    private async void SetViewpoint(Viewpoint vp)
      if (vp != null)
        var actualVp = this.AssociatedObject.GetCurrentViewpoint(ViewpointType.BoundingGeometry);
        if (actualVp == null || (actualVp != null && !actualVp.Equals(vp)))
          Debug.WriteLine("SetViewpoint");
          await this.AssociatedObject.SetViewpointAsync(vp);
Note that I had to wrote a BehaviorBase class to implement a Behavior code that in WPF already exits. Now this that the Xamarin.Forms looks like in Windows and Android:
UWP App
Android App
To see the complete solution go to this github repo https://github.com/marceloctorres/GeonetPost.Xamarin
Finally, no make a zoom to your trace route, only set the Viewport property in the MapPageViewModel class with a new Viewport using your polyline extent geometry. For example:
 ViewPoint = new Viewpoint(route.Extent);
And the SetMapViewViewportBehavior does the rest.
Marcelo
Marcelo César Torres
NadirHussain
Dear Marcelo,
 I implement the code like you suggest.Its working great.I am facing other issue.I want to implement the mapview GeoViewTapped event.how to apply this in MVVM.
waiting for reply.
Thanks for your kind cooperation.
NadirHussain
Dear Marcelo,
 I implement the code below for GeoViewTapped event.Behaviour class for tabbed event.
using System;
using System.Collections.Generic;
using System.Text;
namespace MasterDetail.Behaviors
class ClsCustomBehviour : BehaviorBase<MapView>
public static readonly BindableProperty CommandProperty = BindableProperty.Create(nameof(Command), typeof(ICommand), typeof(ClsCustomBehviour));
public ICommand Command
get { return (ICommand)GetValue(CommandProperty); }
set
SetValue(CommandProperty, value);
protected override void OnAttachedTo(MapView bindable)
base.OnAttachedTo(bindable);
bindable.GeoViewTapped += this.TabbedPointAction;
/// <summary>
/// </summary>
/// <param name="bindable"></param>
protected override void OnDetachingFrom(MapView bindable)
base.OnDetachingFrom(bindable);
bindable.GeoViewTapped -= this.TabbedPointAction;
private void TabbedPointAction(object sender, Esri.ArcGISRuntime.Xamarin.Forms.GeoViewInputEventArgs e)
if (this.Command != null)
var mapClickPoint = e.Location;
if (this.Command.CanExecute(mapClickPoint))
this.Command.Execute(mapClickPoint);
////View XAML////
<esriUI:MapView Map="{Binding MyMap}"
<esriUI:MapView.Behaviors>
<bh:ClsCustomBehviour Command="{Binding TabbedClickCommand}" />
</esriUI:MapView.Behaviors>
</esriUI:MapView>
above is my view.
///View MODEL CLASS
// TabbedClickCommand = new DelegateCommand<MapPoint>(tabbedPoint);
TabbedClickCommand = new DelegateCommand(tabbedPoint);
private void tabbedPoint()
Debug.WriteLine("Hello");
throw new NotImplementedException();
when i click on the map the code run it comes into tabbedpoint event.and print hello.But when i execute like
private void tabbedPoint(MapPoint obj)
my code not execute.i could not find the way how to execute the below function.Because i need clicked location point for further process.Please help me.how to solve.
Thanks again.
Waiting........................
AnttiKajanus1
You can follow the same approach described in https://community.esri.com/message/520348
NadirHussain
Dear Antti Kajanus
i read this.I need the sample example.so i fallow that.i try for GITHUB but link is not working.Please provide some samle example.
