How to get a point along a Polyline
4622
04-08-2016 10:29 AM
HuyHo
I am given a Polyline, how do I determine the MapPoint that is say 3/4 in distance along that line starting at one end? I've search the GeometryEngine class method but couldn't find anything that would help me figure this out.
dotMorten_esri
Esri Notable Contributor
There currently isn't a way to perform this automatically with GeometryEngine.
You'll have to calculate the distance between each line segment one by one and sum it up until you exceed the distance. Then calculate the fraction you need to be down the line of the last line segment.
dotMorten_esri
MichaelBranscomb
Esri Frequent Contributor
Hi Huy,
We do include some Linear Referencing geoprocessing tools with the LocalServer, but I don't know if you are currently using the LocalServer component in your solution.
We support the following tools (Local Server geoprocessing tools support—ArcGIS Runtime SDK for .NET | ArcGIS for Developers​:
Calibrate Routes
Create Routes
Dissolve Route Events
Locate Features Along Routes
Make Route Event Layer
Overlay Route Events
Transform Route Events
Cheers
Mike
HuyHo
We are dealing with a runtime *.geodatabase file in this case and we try to avoid using the local server in this case.  We'll try the approach Morten suggested.  Thanks.
