How do I change license at runtime?
976
05-07-2025 02:00 AM
ViktorSafar
WPF app used by multiple users, they log in via Portal popup. I retrieve the license from Portal but then try to re-init ArcGIS for 2nd and further users, I get an exception:
Esri.ArcGISRuntime.ArcGISRuntimeException: 'License level fixed: License locked at the developer level'
ArcGISRuntimeEnvironment.Initialize(conf =>
    conf.UseLicense(licenseInfo.ToJson());
dotMorten_esri
Esri Notable Contributor
Once your app is licensed, you can only license "up", ie license for a higher-level license. There's no way to re-license the application without restarting.
dotMorten_esri
dotMorten_esri
Btw the specific error you're getting should only happen if you've used features that requires a license before you attempted to license the application.
