How do I add an WMTS layer?
9289
16
12-12-2016 01:48 AM
MatthiasPorges
I'm kinda lost here.
I basically just want to add a Layer for basemap.at - see here: https://www.basemap.at/wmts/1.0.0/WMTSCapabilities.xml
How do I do this? Do I use ArcGISTiledLAyer? ArcGISMapImageLayer? Which Uri?
The only documentation about WMTS I found was a "PortalItemType". If I need a "ArcGISPortal", what should I use as an Uri here?
Tags (1)
dotMorten_esri
Esri Notable Contributor
Actually OpenStreetMap didn't make it either.  However here's a custom tiled layer that renders OSM. You can probably tweak it to work for your WMTS service.
public class OpenStreetMapLayer : Esri.ArcGISRuntime.Mapping.ServiceImageTiledLayer
     public OpenStreetMapLayer()
            : base(CreateTileInfo(), new Envelope(-20037508.3427892, -20037508.3427892, 20037508.3427892, 20037508.3427892, SpatialReferences.WebMercator))
     private static Esri.ArcGISRuntime.ArcGISServices.TileInfo CreateTileInfo()
          var levels = new Esri.ArcGISRuntime.ArcGISServices.LevelOfDetail[19];
          double resolution = 20037508.3427892 * 2 / 256;
          double scale = resolution * 96 * 39.37;
          for (int i = 0; i < levels.Length; i++)
               levels[i] = new Esri.ArcGISRuntime.ArcGISServices.LevelOfDetail(i, resolution, scale);
               resolution /= 2;
               scale /= 2;
          return new Esri.ArcGISRuntime.ArcGISServices.TileInfo(96, TileImageFormat.Png, levels, new MapPoint(-20037508.3427892, 20037508.3427892, SpatialReferences.WebMercator),
               SpatialReferences.WebMercator, 256, 256);
     private static string[] subdomains = { "a", "b", "c" };
     protected override Task<Uri> GetTileUriAsync(int level, int row, int column, CancellationToken cancellationToken)
          return Task.FromResult(new Uri($"http://{ subdomains[(level + column + row) % subdomains.Length]}.tile.openstreetmap.org/{level}/{column}/{row}.png", UriKind.Absolute));
PreetiMaske
WMTS support is not available in the released version but it's up on the list for next release.
MatthiasPorges
Is there no workaround for adding a single layer?
I was told, the SDK supports "Open Street Map", which uses the same protocol as basemap.at.
dotMorten_esri
               resolution /= 2;
               scale /= 2;
MatthiasPorges
This works, thank you!
You don't happen to have a similar workaround/implementation for ServiceFeatureTable from WMS?
Pierre-JeanMuller
here is the code in order to show wmts tiles
row = (int)(Math.Pow(2, level) - row - 1);
 string uriString = tilesUri + $"/{level}/{column}/{row}.png";
return Task.FromResult(new Uri(uriString, UriKind.Absolute));
Parh_JinChia
with version 100.1.0 of the SDK for .Net, support for WMTS is supposed to be here as mentioned in the release notes.
However, I could still find no documentation on this.
How do I take in a WMTS map? I was using 10.2.4 previously, I had hoped to do something like that...
NagmaYasmin
Hi Parh,
WmtsLayer (WmtsLayer Class) is introduced in 100.1 to display WMTS layer. If you have downloaded the sample, there is an example how to consume the WMTS service using Runtime .net application.
Hope that helps,
Nagma
WmtsLayer
Parh_JinChia
Thanks Yasmin. I have gotten it working now.
I am trying to work on something lightweight and cost nothing.
My current solution is to use open street map data in a local installation
of geoserver,
that is why I am using WMTS.
I would like to know whether there is any simpler solution?
i.e. is there any way for Esri Arcgis .NET SDK to consume local map data
(or even a geotagged image)?
I know there are map packages that can be generated from ArcGIS Desktop,
but that would require me to
buy ArcGIS desktop, so I am not going that direction..
thanks in advance for any pointers.
rgds
PJ
dotMorten_esri
