How can I import a CAD (eg. DWG) file to a map layer using the SDK?
4259
05-11-2015 03:52 AM
JonasLund
How can I import a CAD (eg. DWG) file to a map layer using the SDK, similarly to importing a shapefile? If the SDK itself cannot do it, is there some kind of SDK extension or redistributable tool that will be able to do it? I guess the process would require a georeferencing step.
I know there is an Data Interoperability extension to ArcGIS for Server that might do it, but redistributing ArcGIS for Server with our software just for this feature seems like overkill, if at all possible.
Tags (3)
