High cpu using NmeaLocationDataSource
1066
06-02-2022 12:03 AM
Moer
UWP, Esri.ArcGISRuntime 100.14.0
Having problem with high cpu usage when using NmeaLocationDataSource with FromStreamCreator on UWP. Can't use FromSerialPort because it's a virtual com port and UWP won't allow that.
When getting gps data from com port it's using 20-50% cpu.
Any ideas?
Ping @dotMorten_esri
dotMorten_esri
Esri Notable Contributor
How did you implement the stream? I've seen issues where the read on the stream isn't blocking and could cause this
Moer
I used the pattern in the api reference:
https://developers.arcgis.com/net/api-reference/api/uwp/Esri.ArcGISRuntime/Esri.ArcGISRuntime.Locati...
var port = new System.IO.Ports.SerialPort("COM7", 9600);
NmeaLocationDataSource serialPortDatasource = NmeaLocationDataSource.FromStreamCreator(
    onStart: (ds) =>
        port.Open();
        return Task.FromResult(port.BaseStream);
    onStop: (ds) =>
        port.Close();
        return Task.CompletedTask;
