Help With FromSerialPort
983
07-25-2022 11:09 AM
pshearon
.NET 6 Target 10.0.22000.0 or less  x64
Esri.ArcGISRuntime.WPF (100.14.1)
Esri.ArcGISRuntime.Toolkit (100.14.1)
System.IO.Ports (6.0.0)
Problem: No response after calling FromSerialPort with proper devices.
The blue-tooth devices connect properly, but I can't get any serial GPS to connect. I do not have this problem in .NET 4.8 using it's constructs (Port name).
Using this sample: https://github.com/Esri/arcgis-runtime-demos-dotnet/tree/main/src/ExternalNmeaGPS
Which also exhibits the same behavior.
Regards,
Patrick Shearon
dotMorten_esri
Esri Notable Contributor
Are you setting the correct baud rate for your device?
pshearon
Yes, 4800.
Here is how I have it working but not using the FromSerialPort. I have to use FromStreamCreator to get it to work.
internal static async void Connect(Device device)
            try
                Disconnect();
                gpsFile = AppDomain.CurrentDomain.BaseDirectory + @"\Offline\" + Statics.App.User.Username + "_" + DateTime.Now.ToString("MM-dd-yyyy_HH-mm-ss") + ".gpsdata";
                //SERIAL PORTS
                if (device.IsSerialPort)
                    string portName = "";
                    using (var ser = await Windows.Devices.SerialCommunication.SerialDevice.FromIdAsync(device.DeviceInfo!.Id))
                        portName = ser.PortName;
                    var port = new System.IO.Ports.SerialPort(portName, 4800);
                    currentGPS = NmeaLocationDataSource.FromStreamCreator(
                        onStart: (ds) =>
                            try
                                port.Open();
                                return Task.FromResult(port.BaseStream);
                            catch (Exception ex)
                                return null;
                        onStop: (ds) =>
                            try
                                port.Close();
                                return Task.CompletedTask;
                    pmc.MyMapView.LocationDisplay.DataSource = currentGPS;
                    pmc.MyMapView.LocationDisplay.IsEnabled = true;
                else
                    //BLUETOOTH
                    var btdevice = await Windows.Devices.Bluetooth.BluetoothDevice.FromIdAsync(device.DeviceInfo!.Id);
                    if (btdevice is not null)
                        currentGPS = NmeaLocationDataSource.FromBluetooth((await btdevice.GetRfcommServicesForIdAsync(RfcommServiceId.SerialPort)).Services.First());
                currentGPS.LocationChanged += Gps_LocationChanged;
                SaveSettings(device);
                Statics.Alert("Connecting to: " + device.Name);
                Statics.Alert(ex.Message);
