GraphicsOverlay HitTestAsync replacement in 100.1
3053
09-08-2017 09:25 AM
ChrisSmith10
JenniferNery
I think you can use GeometryEngine methods then to see if your selection rectangle intersects with the graphic geometries.
        private async void OnSelect(object sender, RoutedEventArgs e)
            try
                var rectangle = await MyMapView.SketchEditor.StartAsync(SketchCreationMode.Rectangle, false);
                foreach (var overlay in MyMapView.GraphicsOverlays)
                    foreach (var graphic in overlay.Graphics)
                        graphic.IsSelected = GeometryEngine.Intersects(graphic.Geometry, rectangle);
            catch (Exception ex)
                MessageBox.Show(ex.Message, ex.GetType().Name);
JenniferNery
The v100.x equivalent for this method is IdentifyGraphicsOverlayAsync providing a tolerance parameter will create the rectangle with this height and width, you can also provide the number of maximum results you want returned. There's also an overload for identifying all graphics overlays versus this one where hit test (or identify) will be done on specified graphics overlay only.
ChrisSmith10
Jennifer,
   The IdentifyGraphicsOverlayAsync method only allows for a square to be specified where  GraphicsOverlay.HitTestAsync Method (ViewBase, Rect, Int32) allows a rectangle.
Our use case is allowing the user to drag a selection rectangle on the map to select objects.
JenniferNery
            try
ChrisSmith10
Jennifer,
   Thank you very much. I'll give that a try.
ChrisSmith10
Jennifer,
  Your suggestion worked well. Thank you.
