GPS Logging
1540
07-25-2022 02:37 PM
pshearon
How can I log NMEA messages coming from a NmeaLocationDataSource?
public event EventHandler<Location>? LocationChanged; <--- this gives a location object, but not the raw messages  that lead to that point. What are the chances of getting those in an event? Or some other way?
Regards,
Patrick Shearon
dotMorten_esri
Esri Notable Contributor
There's no out-of-the-box support for this today (it's on our backlog). However, you could intercept the NMEA stream with a stream interceptor class. For example:
public class StreamInterceptor : Stream
    private readonly Stream _baseStream;
    public StreamInterceptor(Stream baseStream)
        _baseStream = baseStream;
    public event EventHandler<string>? OnData;
    public override int Read(byte[] buffer, int offset, int count)
        int read = _baseStream.Read(buffer, offset, count);
        if (read > 0)
            OnData?.Invoke(this, Encoding.UTF8.GetString(buffer, 0, read));
        return read;
    public override bool CanRead => _baseStream.CanRead;
    public override bool CanSeek => _baseStream.CanSeek;
    public override bool CanWrite => _baseStream.CanWrite;
    public override long Length => _baseStream.Length;
    public override long Position { get => _baseStream.Position; set => _baseStream.Position = value; }
    public override void Flush() => _baseStream.Flush();
    public override long Seek(long offset, SeekOrigin origin) => _baseStream.Seek(offset, origin);
    public override void SetLength(long value) => _baseStream.SetLength(value);
    public override void Write(byte[] buffer, int offset, int count) => _baseStream.Write(buffer, offset, count);
Then you could create the nmea datasource using this new stream type and listen to the OnData event:
SerialPort p = new SerialPort("COM3");
NmeaLocationDataSource ds = NmeaLocationDataSource.FromStreamCreator(
    onStart: (ds) =>
        p.Open();
        var sl = new StreamInterceptor(p.BaseStream);
        sl.OnData += (s, nmeaString) =>
            Console.Write(nmeaString); // NMEA raw data string
        return Task.FromResult<System.IO.Stream>(sl);
    onStop: (ds) =>
        p.Close();
        return Task.CompletedTask;
ds.StartAsync();
pshearon
What would you recommend for FromBluetooth devices?
dotMorten_esri
If you're using .NET 6, you don't actually need to use the bluetooth version, but can still use them as a serial port (Windows will assign them port numbers). But otherwise, you'd have to grab the bluetooth data stream yourself before using the above.
pshearon
Thanks a lot, your insight has been very helpful. Since it's all on windows (.NET 6) I will be going with System.IO.Ports.SerialPort and that StreamInterceptor.  All of my tests worked with your suggestions!
Regards,
Patrick Shearon
FelicityRhone
I know this is a very old thread, but I was just looking for this and found that there is an event now as of the Maps SDK 200.7. So, for anyone else landing here in the future:
https://developers.arcgis.com/net/api-reference/api/netwin/Esri.ArcGISRuntime/Esri.ArcGISRuntime.Loc...
