Hello,
I am trying to use the local server. The service is starting without errors, but it is not visible when added to the map.
private Esri.ArcGISRuntime.LocalServices.LocalServer _localServer;
ArcGISMapImageLayer localServiceLayer;
private async void StartLocalServer()
// Get the singleton LocalServer object using the static "Instance" property
_localServer = Esri.ArcGISRuntime.LocalServices.LocalServer.Instance;
//_localServer.AppDataPath = @"C:\Temp\localserver";
// Handle the StatusChanged event to react when the server is started
_localServer.StatusChanged += ServerStatusChanged;
// Start the local server instance
await _localServer.StartAsync();
private void ServerStatusChanged(object sender, Esri.ArcGISRuntime.LocalServices.StatusChangedEventArgs e)
// Check if the server started successfully
if (e.Status == Esri.ArcGISRuntime.LocalServices.LocalServerStatus.Started)
LocalMapService localmapService = new LocalMapService(@"G:\GISData\myData.mpk");
//MessageBox.Show(localmapService.Status.ToString());
localmapService.StatusChanged += (svc, args) =>
// If started successfully, add a layer from the service
if (args.Status == LocalServerStatus.Started)
// Get the service URL
var mapServiceUrl = (svc as LocalMapService).Url;
// Create a new ArcGISMapImageLayer
localServiceLayer = new ArcGISMapImageLayer(mapServiceUrl);
localServiceLayer.LoadAsync();
// Set layer opacity to semi-transparent
localServiceLayer.Opacity = 1;
// Add the layer to the map
MainMapView.Map.OperationalLayers.Add(localServiceLayer);
// Start the local map service
localmapService.StartAsync();
Solved! Go to Solution.
I got it, the data have to be projected to mercator, if not, it is not visualised. I don't know if it is an error or a prerequest for the localserver
Just to add some details that may help finding a solution :
When I look to the Image layer parameters, I find this in the "Spatial reference" field : SpatialReference = 'localServiceLayer.SpatialReference' threw an exception of type 'System.InvalidOperationException'
If I use mpkx file (resulted from arcgis pro), I got : Failed to create service delme MapServer. Service failed to initialize: IObjectConstruct::Construct (MapServer) hr=0x80043000 (ErrorInfo did not include a description)
The ArcGISMapImageLayer should request a map image from the LocalMapServices in the spatial reference of the MapView so this might be a bug (although we do always recommend that your data should share a common spatial reference, to avoid the overhead of reprojecting on the fly).
What data formats/types are in your MPK and what other layers are in your Map (both basemap and operational)?
Cheers
Mike
thanks for your answer. In fact, I can understand that a .mpk file has to use the same spatial reference as the MapView, but I only expected to get some error message.
In my MapView, I has one elevation layer of WGS84(4326) from an arcgis server + graphics layer + openstreetmap layer.
In the mpk, I had WGS84(4326) layer. I reproject it to epsg:3857 to be able to visualise it.
