GeometryEditor higher fidelity updates than Geometry property?
3182
8
04-03-2024 08:42 AM
Mike_Quetel
I'm using the GeometryEditor for the interactive portion of a measure tool.  As the Geometry property changes, the length of the line (or area of the polygon) is updated for the user.  I'm interested in higher fidelity updates that track the sketch rubberbanding as the user moves the mouse... is this possible?  I'm sort of stuck at 200.2 as we await our IT group to roll out .NET 8 widely.
Thanks in advance!
MQ
(view in My Videos)
SomeGISGuy
Sorry! I got my versions mixed up, because we're deep into finishing 200.4 up right now 🙂
You're right. 200.2 included the first version of the new geometry editor, 200.3 required net8. No need to move up in versions to get access to it.
So in that case, I misunderstood your question. Could you clarify what you mean by "higher fidelity" ?
wrt self-contained deployment: No admin required. It's just a larger deployment that you can literally x-copy deploy if you wanted to. (It does mean if there are security updates to .NET 8 you're also responsible for updating the .net8 version embedded in your application)
SomeGISGuy
200.3 has the new geometry editor which features rubberbanding, so you could use that until you move to .NET 8. There was a few GeometryEditor fixes in 200.4 though.
Also one cool thing about .NET 8 is it allows you to deploy .NET 8 with the app, so you really don't need to require a system-wide rollout, since you can just ship it locally in your app. https://learn.microsoft.com/en-us/dotnet/core/deploying/#publish-self-contained
Mike_Quetel
Thanks Morten.  I was under the impression that 200.3 not only supported .NET 8 but required it.  I'll look into the self contained deployment option... our users install/update the app without admin permissions, so that would be a requirement.
SomeGISGuy
Mike_Quetel
The geometry property isn't updated until a vertex is placed.  I'm interested in recalculating the length while the user is moving the mouse around and the drawing feedback of the editor is tracking the mouse location.  I suppose I could do this with window events like mousemove, but was hoping the geometryeditor supported this natively.
SomeGISGuy
I see. There's no event currently to track the "temporary" state the geometry is in, so you'd have to use the mouse-move event to "append" that extra bit.
Mike_Quetel
Re-visiting this old question:  Would the HoveredElementChanged event or PickedUpElementChanged  which are new to the the GeometryEditor at 200.8 help with accessing the temporary state of the geometry?  Looking for something more native to the maps SDK that would allow for an ArcGIS Pro like measure tool.
dotMorten_esri
Esri Notable Contributor
Mike_Quetel
I have and I'm not satisfied with how it would integrate into my existing app from a visual style perspective.  Any thoughts on if either of those 2 new events would allow me to get the constantly changing length of a line as the user actively sketches it?
