GeometryEditor FeedbackLine access
2700
10
09-27-2024 12:43 AM
DmitriyKolokolnikov
Can I access the FeedbackLine when dragging a node in the GeometryEditor to display, for example, the current polyline length during the drag? Thanks
HamishDuff
Hi @DmitriyKolokolnikov,
Thank you for your question. Currently you cannot access the FeedbackLine length during a drag action, as you've mentioned it is only possible to retrieve the length after a subsequent vertex has been placed.
I'll make a note of this as a potential enhancement.
GKmieliauskas
I think link to another thread could be helpful for you:
Solved: Add GeometryChanged event to the new GeometryEdito... - Esri Community
DmitriyKolokolnikov
Thank you for the quick response. Unfortunately, this is not quite what I need. I need to obtain the geometry during the process of dragging a vertex. It seems that currently it’s only possible to get the geometry at the end of the dragging, i.e., after releasing the mouse.
GKmieliauskas
Have you read blog about migrating from SketchEditor -> GeometryEditor inside the thread I mentioned above. Look at the part "Asynchronous start task with geometry result"
DmitriyKolokolnikov
Yes, I have read that. I can get the geometry, but only after the node dragging is complete. However, I need to get it during the dragging.
GKmieliauskas
If you need to get it during dragging you need to listen for PropertyChanged event as in sample from thread:
mapView.GeometryEditor.PropertyChanged += (s, e) =>
    if (e.PropertyName == nameof(mapView.GeometryEditor.Geometry))
        // Geometry has changed
DmitriyKolokolnikov
The PropertyChanged for the GeometryEditor.Geometry property is triggered only after the vertex dragging is completed, i.e., after the mouse button is released.
HamishDuff
Mike_Quetel
I'd like to register support for this as an enhancement. It sounds like OP and I have similar use cases where we would like to provide continuous feedback (length, area, etc.) about the interim geometry before a vertex is actually placed by the user.
FelicityRhone
I also have a use case where getting the geometry of the feedback line would be useful. I guess I can calculate it myself from the mouse position to the current selected vertex, but it would be handy if it was more accessible somehow. I want to show the user a label with the length of the feedback line displayed as they're drawing (among other things). Any update on this as a feature enhancement request, i.e. is the request tracked somewhere?
