Feature Service Label Placement: Lines & Polygons
1452
09-08-2017 03:05 PM
MarkCederholm
I have two layers in a feature service: one polyline and one polygon.  The label placements are "esriServerLinePlacementAboveAlong" and "esriServerPolygonPlacementAlwaysHorizontal" respectively.  When I create a runtime gdb from the services, the labels look pretty much as expected in 10.2.7.  In 100.1, however, I can only see the labels if I zoom in right up to a feature.  Is there a different placement I should be using?
MarkCederholm
    Using "esriServerLinePlacementAboveEnd" works for lines, but there's only one available placement for polygons.
