Exported offline tiles are not zooming to street level
910
06-09-2020 01:12 AM
KavitaPandey
Requirement:
I need to provide basemaps in offline mode, I should be able to download basemap's tiles in mobile device and use it when no connectivity.
My scenarios:
1. I  used the ExportTileCacheTask on mobile and exported the basemap for offline use,  and  I am able to download .tpk file giving the required extent.
2. The map URL  that I am using to export is "https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer "
3. I need to zoom
Question:
Problem is no matter what I give Maxscale and Minscale while exporting, my map is not getting zoom till street level. I even tried exporting as small as the area possible. So, is it the limitation of exporting Basemap that it can't be exported till the street level? or this is the limitation of basemap URL i am using and there's any better base map URL out there?
MichaelBranscomb
Esri Frequent Contributor
For the area of interest and levels of detail you're trying to download, what results do you receive from the ExportTileCacheTask.EstimateTileCacheSize Method ? (that service has a limit of 150,000 tiles)
Mike
