Exception when zooming up-down
2333
12-13-2018 01:59 AM
Jean-ChristopheBertolini
ArcGIS Runtime 100.3
App WPF
Layers : shapefile + Feature Layer + OpenStreetMap
This is just for information if that can help developers:
Esri.ArcGISRuntime.ArcGISRuntimeException
  HResult=0x80131500
  Message=Internal error exception. Error creating depth stencil view!:
c:\daily_r\rtc\runtimecore\c_api\src\mapping\map_view\geo_view.cpp(203) : error : Exception caught in RT_GeoView_pulse
  Source=Esri.ArcGISRuntime
  Arborescence des appels de procédure :
   à Esri.ArcGISRuntime.ArcGISException.HandleCoreError(CoreError error, Boolean throwException)
   à RuntimeCoreNet.GeneratedWrappers.Interop.CheckError(IntPtr errorHandle, Boolean throwOnFailure, GCHandle wrapperHandle)
   à RuntimeCoreNet.GeneratedWrappers.CoreGeoView.Pulse()
   à Esri.ArcGISRuntime.UI.Controls.GeoView.Esri.ArcGISRuntime.Internal.IDxSurfaceSource.Pulse()
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.CompositionTarget_Rendering(Object sender, EventArgs e)
   à System.Windows.WeakEventManager.ListenerList`1.DeliverEvent(Object sender, EventArgs e, Type managerType)
   à System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args)
   à Esri.ArcGISRuntime.Internal.RenderingWeakEventManager.OnCompositeTargetRendering(Object sender, EventArgs e)
   à System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   à System.Windows.Media.MediaContext.AnimatedRenderMessageHandler(Object resizedCompositionTarget)
   à System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   à System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   à System.Windows.Threading.DispatcherOperation.InvokeImpl()
   à System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   à MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   à MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   à System.Windows.Threading.DispatcherOperation.Invoke()
   à System.Windows.Threading.Dispatcher.ProcessQueue()
   à System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   à MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   à MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   à System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   à MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   à MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   à System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   à System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   à Esri.ArcGISRuntime.Internal.HostedSurfaceElement.SurfaceBackgroundUiWorker(Object arg)
   à System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   à System.Threading.ThreadHelper.ThreadStart(Object obj)
MichaelBranscomb
Esri Frequent Contributor
This error appears to come from our DirectX11-based rendering code.
Please can you run dxdiag on the machine where you saw this error, and attach the results? (https://support.microsoft.com/en-us/help/4028644/windows-open-and-run-dxdiagexe)
It may also be worth checking for an updated graphics driver: either from the device vendor or from the graphics card vendor.
Cheers
Mike
Hi Mike,
Please find here after the result.
jcb
System Information
      Time of this report: 12/13/2018, 16:39:55
             Machine name: JCBERTOLINI03
               Machine Id: {357FA637-FF2C-4E9E-BCC0-501D1194696D}
         Operating System: Windows 10 Professionnel 64-bit (10.0, Build 17134) (17134.rs4_release.180410-1804)
                 Language: French (Regional Setting: French)
      System Manufacturer: Hewlett-Packard
             System Model: HP ProDesk 490 G2 MT
                     BIOS: BIOS Date: 10/15/14 16:21:51 Ver: 04.06.05 (type: BIOS)
                Processor: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz (8 CPUs), ~3.6GHz
                   Memory: 16384MB RAM
      Available OS Memory: 16310MB RAM
                Page File: 10215MB used, 8526MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.17134.0001 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
           Card name: Intel(R) HD Graphics 4600
        Manufacturer: Intel Corporation
           Chip type: Intel(R) HD Graphics Family
            DAC type: Internal
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_21F5103C&REV_06
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 2160 MB
    Dedicated Memory: 112 MB
       Shared Memory: 2048 MB
        Current Mode: 1920 x 1080 (32 bit) (60Hz)
         HDR Support: Not Supported
    Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.636242,0.334484), Green(0.309094,0.623547), Blue(0.150891,0.067883), White Point(0.313977,0.329602)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: HP ZR2330w
          Monitor Id: HWP3069
         Native Mode: 1920 x 1080(p) (60.000Hz)
         Output Type: DVI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
         Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll
 Driver File Version: 20.19.0015.4835 (English)
      Driver Version: 20.19.15.4835
         DDI Version: 12
      Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
        Driver Model: WDDM 2.0
 Graphics Preemption: Primitive
  Compute Preemption: Thread group
            Miracast: Not Supported by WiFi driver
 Hybrid Graphics GPU: Integrated
      Power P-states: Not Supported
      Virtualization: Not Supported
          Block List: No Blocks
  Catalog Attributes: Universal:N/A Declarative:N/A
   Driver Attributes: Final Retail
    Driver Date/Size: 16/10/2017 01:00:00, 39861272 bytes
         WHQL Logo'd: Yes
     WHQL Date Stamp: Unknown
   Device Identifier: {D7B78E66-4752-11CF-6F61-FA01BAC2D935}
           Vendor ID: 0x8086
           Device ID: 0x0412
           SubSys ID: 0x21F5103C
         Revision ID: 0x0006
  Driver Strong Name: oem1.inf:5f63e534dd898f5e:iHSWD_w10:20.19.15.4835:pci\ven_8086&dev_0412&subsys_21f5103c
      Rank Of Driver: 00D10001
         Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
         DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  DXVA2_ModeHEVC_VLD_Main
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
        D3D9 Overlay: Supported
             DXVA-HD: Supported
        DDraw Status: Enabled
          D3D Status: Enabled
          AGP Status: Enabled
       MPO MaxPlanes: 1
            MPO Caps: Not Supported
         MPO Stretch: Not Supported
     MPO Media Hints: Not Supported
         MPO Formats: Not Supported
    PanelFitter Caps: Not Supported
 PanelFitter Stretch: Not Supported
Sound Devices
            Description: Haut-parleurs (Realtek High Definition Audio)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0221&SUBSYS_103C21F5&REV_1000
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7548 (English)
            WHQL Logo'd: Yes
          Date and Size: 30/06/2015 00:00:00, 4525800 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Souris
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Clavier
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: USB Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0461, 0x0010
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Hub USB racine (USB 3.0)
| Vendor/Product ID: 0x8086, 0x8CB1
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 11/9/2018 03:49:37, 565048 bytes
+-+ Périphérique USB composite
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 4/12/2018 00:33:52, 168864 bytes
| +-+ Périphérique d’entrée USB
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 4/12/2018 00:33:52, 42496 bytes
| | | Driver: hidclass.sys, 4/12/2018 00:33:52, 173568 bytes
| | | Driver: hidparse.sys, 6/8/2018 10:01:36, 46080 bytes
| | +-+ Périphérique clavier PIH
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 4/12/2018 00:33:52, 40448 bytes
| | | | Driver: kbdclass.sys, 4/12/2018 00:33:52, 63904 bytes
| | Vendor/Product ID: 0x0461, 0x4D0F
| | Service: HidUsb
| +-+ Souris HID
| | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | Service: mouhid
| | | Driver: mouhid.sys, 4/12/2018 00:33:52, 33280 bytes
| | | Driver: mouclass.sys, 4/12/2018 00:33:52, 56728 bytes
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 442.2 GB
Total Space: 939.9 GB
File System: NTFS
      Model: WDC WD10EZEX-60M2NA0
      Drive: 😧
 Free Space: 1.0 GB
Total Space: 12.8 GB
File System: NTFS
      Drive: E:
 Free Space: 0.1 GB
Total Space: 0.1 GB
File System: FAT32
      Drive: G:
      Model: hp DVDRAM GTB0N
     Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.17134.0137 (French), 6/15/2018 05:36:47, 159744 bytes
System Devices
     Name: Intel(R) H97 Chipset LPC Controller - 8CC6
Device ID: PCI\VEN_8086&DEV_8CC6&SUBSYS_21F5103C&REV_00\3&11583659&0&F8
   Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:49, 18848 bytes
     Name: Contrôleur hôte PCI vers USB standard étendu
Device ID: PCI\VEN_8086&DEV_8CAD&SUBSYS_21F5103C&REV_00\3&11583659&0&D0
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 95648 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 412576 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 514464 bytes
     Name: Contrôleur AHCI SATA standard
Device ID: PCI\VEN_8086&DEV_8C82&SUBSYS_21F5103C&REV_00\3&11583659&0&FA
   Driver: C:\WINDOWS\system32\DRIVERS\storahci.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:49, 156056 bytes
     Name: Intel(R) 9 Series Chipset Family PCI Express Root Port 1 - 8C90
Device ID: PCI\VEN_8086&DEV_8C90&SUBSYS_21F5103C&REV_D0\3&11583659&0&E0
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.17134.0441 (French), 11/9/2018 03:48:23, 375296 bytes
     Name: Intel(R) 9 Series Chipset Family SMBus Host Controller - 8CA2
Device ID: PCI\VEN_8086&DEV_8CA2&SUBSYS_21F5103C&REV_00\3&11583659&0&FB
   Driver: n/a
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_21F5103C&REV_0C\01000000684CE00000
   Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 10.03.0723.2015 (French), 2/17/2016 16:27:02, 896768 bytes
   Driver: C:\WINDOWS\system32\RtNicProp64.dll, 1.02.0000.0006 (French), 2/17/2016 16:27:02, 91240 bytes
     Name: Pont processeur hôte standard PCI
Device ID: PCI\VEN_8086&DEV_0C00&SUBSYS_21F5103C&REV_06\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) HD Graphics 4600
Device ID: PCI\VEN_8086&DEV_0412&SUBSYS_21F5103C&REV_06\3&11583659&0&10
   Driver: C:\WINDOWS\system32\DRIVERS\igdkmd64.sys, 20.19.0015.4835 (English), 12/22/2017 01:22:16, 7972296 bytes
   Driver: C:\WINDOWS\system32\igd10iumd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:16, 16451000 bytes
   Driver: C:\WINDOWS\system32\igd10idpp64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:10, 312264 bytes
   Driver: C:\WINDOWS\system32\igd11dxva64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:20, 33471440 bytes
   Driver: C:\WINDOWS\system32\igd12umd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:26, 4268488 bytes
   Driver: C:\WINDOWS\system32\igdumdim64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:44, 39861272 bytes
   Driver: C:\WINDOWS\system32\igdail64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:58, 192992 bytes
   Driver: C:\WINDOWS\system32\igfxcmrt64.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:06, 183944 bytes
   Driver: C:\WINDOWS\system32\igfx11cmrt64.dll, 5.00.0000.1148 (English), 12/22/2017 01:21:58, 182920 bytes
   Driver: C:\WINDOWS\system32\igfxcmjit64.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:40, 1590752 bytes
   Driver: C:\WINDOWS\system32\igdde64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:34, 222696 bytes
   Driver: C:\WINDOWS\system32\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 12/22/2017 01:24:08, 448968 bytes
   Driver: C:\WINDOWS\system32\igdusc64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:48, 6693112 bytes
   Driver: C:\WINDOWS\system32\igc64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:00, 15477944 bytes
   Driver: C:\WINDOWS\system32\igdmd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:40, 2393128 bytes
   Driver: C:\WINDOWS\SysWow64\igd10iumd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:10, 13062744 bytes
   Driver: C:\WINDOWS\SysWow64\igd10idpp32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:04, 297128 bytes
   Driver: C:\WINDOWS\SysWow64\igd11dxva32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:18, 34824440 bytes
   Driver: C:\WINDOWS\SysWow64\igd12umd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:22, 4240176 bytes
   Driver: C:\WINDOWS\SysWow64\igdumdim32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:40, 38903864 bytes
   Driver: C:\WINDOWS\SysWow64\igdail32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:54, 173536 bytes
   Driver: C:\WINDOWS\SysWow64\igdde32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:30, 181792 bytes
   Driver: C:\WINDOWS\SysWow64\igfxcmrt32.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:02, 160232 bytes
   Driver: C:\WINDOWS\SysWow64\igfx11cmrt32.dll, 5.00.0000.1148 (English), 12/22/2017 01:21:54, 160232 bytes
   Driver: C:\WINDOWS\SysWow64\igfxcmjit32.dll, 5.00.0000.1148 (English), 12/22/2017 01:22:36, 1178592 bytes
   Driver: C:\WINDOWS\SysWow64\igdusc32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:48, 5137776 bytes
   Driver: C:\WINDOWS\SysWow64\igc32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:00, 13483160 bytes
   Driver: C:\WINDOWS\SysWow64\igdmd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:34, 1858600 bytes
   Driver: C:\WINDOWS\SysWow64\iglhcp32.dll, 3.00.0001.0026 (English), 12/22/2017 01:22:16, 205320 bytes
   Driver: C:\WINDOWS\SysWow64\iglhsip32.dll, 9.00.0030.9000 (English), 12/22/2017 01:22:26, 1814024 bytes
   Driver: C:\WINDOWS\SysWow64\IntelCpHeciSvc.exe, 9.00.0018.0917 (English), 12/22/2017 01:24:12, 502720 bytes
   Driver: C:\WINDOWS\system32\iglhxs64.vp, 12/22/2017 01:09:48, 4862 bytes
   Driver: C:\WINDOWS\system32\iglhxo64.vp, 12/22/2017 01:09:48, 40343 bytes
   Driver: C:\WINDOWS\system32\iglhxc64.vp, 12/22/2017 01:09:48, 40316 bytes
   Driver: C:\WINDOWS\system32\iglhxg64.vp, 12/22/2017 01:09:48, 39658 bytes
   Driver: C:\WINDOWS\system32\iglhxo64_dev.vp, 12/22/2017 01:09:48, 40931 bytes
   Driver: C:\WINDOWS\system32\iglhxc64_dev.vp, 12/22/2017 01:09:48, 41296 bytes
   Driver: C:\WINDOWS\system32\iglhxg64_dev.vp, 12/22/2017 01:09:48, 39798 bytes
   Driver: C:\WINDOWS\system32\iglhxa64.vp, 12/22/2017 01:09:48, 1125 bytes
   Driver: C:\WINDOWS\system32\iglhxa64.cpa, 12/22/2017 01:09:48, 2813952 bytes
   Driver: C:\WINDOWS\system32\iglhcp64.dll, 3.00.0001.0026 (English), 12/22/2017 01:22:20, 242112 bytes
   Driver: C:\WINDOWS\system32\iglhsip64.dll, 9.00.0030.9000 (English), 12/22/2017 01:22:30, 1816680 bytes
   Driver: C:\WINDOWS\system32\cp_resources.bin, 12/22/2017 01:09:44, 511260 bytes
   Driver: C:\WINDOWS\system32\difx64.exe, 1.04.0004.0000 (English), 12/22/2017 01:21:08, 175552 bytes
   Driver: C:\WINDOWS\system32\igfxDH.dll, 6.15.0010.4835 (English), 12/22/2017 01:22:52, 755168 bytes
   Driver: C:\WINDOWS\system32\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:22:56, 84960 bytes
   Driver: C:\WINDOWS\system32\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:22:58, 95200 bytes
   Driver: C:\WINDOWS\system32\igfxDI.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:02, 398304 bytes
   Driver: C:\WINDOWS\system32\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:06, 29152 bytes
   Driver: C:\WINDOWS\system32\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:06, 29152 bytes
   Driver: C:\WINDOWS\system32\igfxLHM.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:34, 2141664 bytes
   Driver: C:\WINDOWS\system32\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:38, 22496 bytes
   Driver: C:\WINDOWS\system32\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:44, 22496 bytes
   Driver: C:\WINDOWS\system32\igfxSDK.exe, 12/22/2017 01:23:48, 1023944 bytes
   Driver: C:\WINDOWS\system32\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:48, 100832 bytes
   Driver: C:\WINDOWS\system32\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:54, 111584 bytes
   Driver: C:\WINDOWS\system32\igfxEM.exe, 6.15.0010.4835 (English), 12/22/2017 01:23:16, 354248 bytes
   Driver: C:\WINDOWS\system32\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:20, 27616 bytes
   Driver: C:\WINDOWS\system32\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 12/22/2017 01:23:20, 27616 bytes
   Driver: C:\WINDOWS\system32\GfxUIEx.exe, 6.15.0010.4835 (English), 12/22/2017 01:21:22, 466880 bytes
   Driver: C:\WINDOWS\system32\Gfxv4_0.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:32, 968128 bytes
   Driver: C:\WINDOWS\system32\Gfxv4_0.exe.config, 12/22/2017 01:09:44, 935 bytes
   Driver: C:\WINDOWS\system32\Gfxv2_0.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:28, 964544 bytes
   Driver: C:\WINDOWS\system32\Gfxv2_0.exe.config, 12/22/2017 01:09:44, 895 bytes
   Driver: C:\WINDOWS\system32\GfxResources.dll, 8.15.0010.4835 (French), 12/22/2017 01:21:18, 5262808 bytes
   Driver: C:\WINDOWS\system32\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (French), 12/22/2017 01:25:20, 704992 bytes
   Driver: C:\WINDOWS\system32\igfxCUIServicePS.dll, 12/22/2017 01:22:48, 103392 bytes
   Driver: C:\WINDOWS\system32\igfxCUIService.exe, 6.15.0010.4835 (English), 12/22/2017 01:22:44, 373704 bytes
   Driver: C:\WINDOWS\system32\igfxCPL.cpl, 12/22/2017 01:22:44, 273376 bytes
   Driver: C:\WINDOWS\system32\igfxTray.exe, 12/22/2017 01:23:58, 401864 bytes
   Driver: C:\WINDOWS\system32\igfxDTCM.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:10, 254944 bytes
   Driver: C:\WINDOWS\system32\igfxHK.exe, 6.15.0010.4835 (English), 12/22/2017 01:23:34, 268224 bytes
   Driver: C:\WINDOWS\system32\igfxOSP.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:44, 389600 bytes
   Driver: C:\WINDOWS\system32\DPTopologyApp.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:12, 232384 bytes
   Driver: C:\WINDOWS\system32\DPTopologyApp.exe.config, 12/22/2017 01:09:44, 935 bytes
   Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe, 8.15.0010.4835 (French), 12/22/2017 01:21:14, 231872 bytes
   Driver: C:\WINDOWS\system32\DPTopologyAppv2_0.exe.config, 12/22/2017 01:09:44, 895 bytes
   Driver: C:\WINDOWS\system32\igfxext.exe, 6.15.0010.4835 (English), 12/22/2017 01:23:30, 236488 bytes
   Driver: C:\WINDOWS\system32\igfxexps.dll, 6.15.0010.4835 (English), 12/22/2017 01:22:12, 55200 bytes
   Driver: C:\WINDOWS\system32\ColorImageEnhancement.wmv, 12/22/2017 01:09:44, 375173 bytes
   Driver: C:\WINDOWS\system32\ImageStabilization.wmv, 12/22/2017 01:09:48, 403671 bytes
   Driver: C:\WINDOWS\system32\FilmModeDetection.wmv, 12/22/2017 01:09:44, 641530 bytes
   Driver: C:\WINDOWS\SysWow64\igfxexps32.dll, 6.15.0010.4835 (English), 12/22/2017 01:23:26, 52704 bytes
   Driver: C:\WINDOWS\system32\ig75icd64.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:40, 11748312 bytes
   Driver: C:\WINDOWS\SysWow64\ig75icd32.dll, 20.19.0015.4835 (English), 12/22/2017 01:21:36, 8734680 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 12/22/2017 01:09:48, 1981 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 12/22/2017 01:09:48, 9788 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 12/22/2017 01:09:48, 34 bytes
   Driver: C:\WINDOWS\SysWow64\Intel_OpenCL_ICD32.dll, 2.00.0002.0000 (English), 12/22/2017 01:25:10, 103904 bytes
   Driver: C:\WINDOWS\SysWow64\IntelOpenCL32.dll, 20.19.0015.4835 (English), 12/22/2017 01:24:16, 318432 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:50, 373216 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:44, 7126496 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:34, 1408480 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:26, 522720 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 12/22/2017 01:09:48, 1223604 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 12/22/2017 01:09:48, 296664 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 12/22/2017 01:09:48, 389300 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 12/22/2017 01:09:48, 1157132 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 12/22/2017 01:09:48, 287436 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 12/22/2017 01:09:48, 389180 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 12/22/2017 01:09:48, 785172 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 12/22/2017 01:09:48, 249992 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 12/22/2017 01:09:48, 350952 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:16, 242656 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:26, 5022688 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:20, 5360096 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:30, 5238240 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.02.2014.0601 (French), 12/22/2017 01:27:06, 208504 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.02.2014.0601 (French), 12/22/2017 01:26:58, 360056 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 12/22/2017 01:27:10, 355960 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 12/22/2017 01:09:48, 1026520 bytes
   Driver: C:\WINDOWS\system32\Intel_OpenCL_ICD64.dll, 2.00.0002.0000 (English), 12/22/2017 01:25:16, 99808 bytes
   Driver: C:\WINDOWS\system32\IntelOpenCL64.dll, 20.19.0015.4835 (English), 12/22/2017 01:24:20, 416224 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:54, 428512 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:44, 9629152 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:34, 1628128 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:30, 669152 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 12/22/2017 01:09:48, 1226660 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 12/22/2017 01:09:48, 358288 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 12/22/2017 01:09:48, 402580 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 12/22/2017 01:09:48, 1159784 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 12/22/2017 01:09:48, 347104 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 12/22/2017 01:09:48, 402468 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 12/22/2017 01:09:48, 788292 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 12/22/2017 01:09:48, 294032 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 12/22/2017 01:09:48, 364424 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 5.02.0000.10094 (English), 12/22/2017 01:26:20, 267744 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:22, 5234144 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:16, 5744608 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.04.0000.0000 (English), 12/22/2017 01:27:26, 5627360 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.02.2014.0601 (French), 12/22/2017 01:27:10, 248440 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.02.2014.0601 (French), 12/22/2017 01:27:02, 438392 bytes
   Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 12/22/2017 01:27:16, 433784 bytes
   Driver: C:\WINDOWS\SysWow64\igdbcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:02, 388576 bytes
   Driver: C:\WINDOWS\SysWow64\igdrcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:30, 4368864 bytes
   Driver: C:\WINDOWS\SysWow64\common_clang32.dll, 4.00.0000.0000 (English), 12/22/2017 01:20:58, 19861472 bytes
   Driver: C:\WINDOWS\SysWow64\igdmcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:26, 3972064 bytes
   Driver: C:\WINDOWS\SysWow64\igdfcl32.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:12, 225248 bytes
   Driver: C:\WINDOWS\system32\igdbcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:06, 438752 bytes
   Driver: C:\WINDOWS\system32\igdrcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:30, 4931040 bytes
   Driver: C:\WINDOWS\system32\common_clang64.dll, 4.00.0000.0000 (English), 12/22/2017 01:21:02, 29101528 bytes
   Driver: C:\WINDOWS\system32\igdmcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:26, 5683680 bytes
   Driver: C:\WINDOWS\system32\igdfcl64.dll, 20.19.0015.4835 (English), 12/22/2017 01:22:16, 266208 bytes
   Driver: C:\WINDOWS\system32\igdclbif.bin, 12/22/2017 01:09:46, 5799386 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:34, 8872552 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.16.0010.0020 (English), 12/22/2017 01:25:24, 4741296 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:38, 1457096 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:25:38, 1350320 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:02, 1358512 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:06, 1358512 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:44, 1471392 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 12/22/2017 01:09:44, 63761 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 12/22/2017 01:09:44, 62217 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 12/22/2017 01:09:44, 846855 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 12/22/2017 01:09:44, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 12/22/2017 01:09:44, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 12/22/2017 01:09:48, 57541 bytes
   Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:34, 9318344 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.16.0010.0020 (English), 12/22/2017 01:25:24, 4919472 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:44, 1810856 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:25:44, 1677488 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:02, 1686192 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp9vd_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:26:06, 1687216 bytes
   Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.16.0010.0020 (English), 12/22/2017 01:22:48, 1836712 bytes
   Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 12/22/2017 01:09:44, 13485 bytes
   Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 12/22/2017 01:09:44, 12873 bytes
   Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 12/22/2017 01:09:44, 1519616 bytes
   Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 12/22/2017 01:09:44, 993 bytes
   Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 12/22/2017 01:09:44, 21523 bytes
   Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 12/22/2017 01:09:48, 12365 bytes
   Driver: C:\WINDOWS\system32\igfxCoIn_v4835.dll, 1.03.0025.0000 (English), 12/22/2017 01:24:02, 234976 bytes
   Driver: C:\WINDOWS\system32\DisplayAudiox64.cab, 12/22/2017 01:09:44, 831685 bytes
     Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_8CBA&SUBSYS_21F5103C&REV_00\3&11583659&0&B0
   Driver: C:\WINDOWS\system32\DRIVERS\TeeDriverx64.sys, 10.00.0030.1054 (English), 9/30/2014 17:47:28, 129312 bytes
   Driver: C:\ProgramData\Microsoft\Windows\DeviceMetadataStore\EN\3f3ca95b-3978-4168-b47b-5444f42d6c89.devicemetadata-ms, 9/30/2014 17:47:28, 938 bytes
   Driver: C:\ProgramData\Microsoft\Windows\DeviceMetadataStore\EN\46a6fdbe-c823-4579-bab6-35f67e01f793.devicemetadata-ms, 9/30/2014 17:47:28, 833 bytes
   Driver: C:\WINDOWS\system32\WdfCoInstaller01011.dll, 1.11.9200.16384 (French), 3/4/2015 22:08:20, 1795952 bytes
     Name: Contrôleur hôte Intel(R) USB 3.0 eXtensible - 1.0 (Microsoft)
Device ID: PCI\VEN_8086&DEV_8CB1&SUBSYS_21F5103C&REV_00\3&11583659&0&A0
   Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.17134.0001 (French), 4/12/2018 00:33:52, 434592 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.17134.0001 (English), 4/12/2018 00:33:52, 123576 bytes
     Name: Contrôleur High Definition Audio
Device ID: PCI\VEN_8086&DEV_8CA0&SUBSYS_21F5103C&REV_00\3&11583659&0&D8
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:45, 86016 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:46, 98304 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.17134.0001 (English), 4/12/2018 00:33:46, 379392 bytes
     Name: Intel(R) 9 Series Chipset Family PCI Express Root Port 3 - 8C94
Device ID: PCI\VEN_8086&DEV_8C94&SUBSYS_21F5103C&REV_D0\3&11583659&0&E2
Device ID: PCI\VEN_8086&DEV_8CA6&SUBSYS_21F5103C&REV_00\3&11583659&0&E8
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.17134.0001
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.17134.0001
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.17134.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.17134.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.17134.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.17134.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.17134.0471
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.17134.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.17134.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.17134.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.17134.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.17134.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.17134.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.17134.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.17134.0471
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.17134.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.17134.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.17134.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.17134.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.17134.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.17134.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.17134.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.17134.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.17134.0112
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.17134.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.17134.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.17134.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.17134.0001
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.17134.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.17134.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.17134.0001
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.17134.0001
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.17134.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.17134.0112
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.17134.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.17134.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.17134.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.17134.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.17134.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.17134.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.17134.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.17134.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.17134.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.17134.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.17134.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.17134.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.17134.0001
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.17134.0471
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.17134.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.17134.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.17134.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.17134.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.17134.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.17134.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.17134.0320
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.17134.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.17134.0001
WDM Streaming Tee/Splitter Devices:
Convertisseur en T/site-à-site,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.17134.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.17134.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.17134.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.17134.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.17134.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.17134.0001
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.17134.0001
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.17134.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.17134.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.17134.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.17134.0441
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0441
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.17134.0441
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.17134.0001
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.17134.0001
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.17134.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.17134.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.17134.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.17134.0001
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,msvidctl.dll,6.05.17134.0001
Encrypt/Tag,0x00200000,0,0,,
PTFilter,0x00200000,0,0,,
XDS Codec,0x00200000,0,0,,
WDM Streaming Communication Transforms:
Audio Renderers:
Haut-parleurs (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.17134.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.17134.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.17134.0001
DirectSound: Haut-parleurs (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.17134.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.16.0010.0020
  Intel® Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.16.0010.0020
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.17134.0001
  Intel® Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.16.0010.0020
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.17134.0001
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.17134.0001
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.17134.0471
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.17134.0001
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.17134.0001
  Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.17134.0471
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.17134.0001
  HEVCVideoExtension
Video Encoders:
  Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.16.0010.0020
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.17134.0001
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.17134.0001
  Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.17134.0471
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.17134.0001
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.17134.0001
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.17134.0112
  HEVCVideoExtensionEncoder
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.17134.0001
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.17134.0407
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.17134.0001
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.17134.0001
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.17134.0376
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.17134.0081
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.17134.0001
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.17134.0001
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.17134.0471
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.17134.0471
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.17134.0471
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.17134.0001
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.17134.0001
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.17134.0001
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.17134.0471
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.17134.0001
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.17134.0471
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.17134.0471
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.17134.0001
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.17134.0001
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.17134.0471
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.17134.0001
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.17134.0471
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.17134.0001
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.17134.0001
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.17134.0001
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.17134.0112
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.17134.0001
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.17134.0001
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.17134.0001
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.17134.0001
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.17134.0001
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.17134.0137
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.17134.0407
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.17134.0471
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableEncoders = 1
EnableDecoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Détecteur d'erreurs 1891846930211596104, type 5
Nom d’événement : RADAR_PRE_LEAK_WOW64
Réponse : Non disponible
ID de CAB : 0
Signature du problème :
P1 : devenv.exe
P2 : 15.8.28010.2026
P3 : 10.0.17134.2.0.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDR142.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER143.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER154.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER17E.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER19E.tmp.txt
Ces fichiers sont peut-être disponibles ici :
Symbole d’analyse :
Nouvelle recherche de la solution : 0
ID de rapport : 3edda694-0969-4550-8f91-f0955720c485
Statut du rapport : 268435456
Récipient avec hachage : 7697688c2fbc89ddca4130c274ace748
GUID CAB :0
+++ WER1 +++:
Détecteur d'erreurs 1474374509742358388, type 5
ID de CAB : 0
P1 : EauPro.App.WPF.exe
P2 : 3.0.0.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDRCCAA.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCBA.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCFA.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCD75.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCDF3.tmp.txt
Symbole d’analyse :
ID de rapport : 62a3d099-f222-4c06-b731-4b0a7c9b2e3f
Récipient avec hachage : 03d41908680f744a647607ce17157f74
GUID CAB :0
+++ WER2 +++:
Détecteur d'erreurs 2267079189276135810, type 1
Nom d’événement : APPCRASH
ID de CAB : 0
P2 : 3.0.0.0
P3 : 5c0e20a1
P4 : KERNELBASE.dll
P5 : 10.0.17134.407
P6 : ade8d4fe
P7 : c0020001
P8 : 00111812
P9 :
P10 :
Fichiers joints :
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2B0B.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B0A.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B2A.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B28.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER3B49.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_EauPro.App.WPF.e_35e85e75b298565c2f838c69f155cde1f273ce_3944f24b_5d334942
Symbole d’analyse :
ID de rapport : ce0c7ff2-fe8f-42b1-9c6b-f34ba87c5404
Récipient avec hachage : e3f5b2f33831200a2f764882da7c1182
GUID CAB :0
+++ WER3 +++:
Détecteur d'erreurs 1282635736330599100, type 5
ID de CAB : 0
P1 : Poseis.DbImport.exe
P2 : 1.0.0.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDR9304.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER9314.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER9325.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER936E.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER939E.tmp.txt
Symbole d’analyse :
ID de rapport : 3727fc61-185f-4655-b6b1-bceeea3f1768
Récipient avec hachage : c2dbbeaa227c542691ccd6681034fabc
GUID CAB :0
+++ WER4 +++:
Détecteur d'erreurs 1553488786874201904, type 5
Nom d’événement : RADAR_PRE_LEAK_64
ID de CAB : 0
P1 : sqlservr.exe
P2 : 2014.120.2569.0
P4 :
P5 :
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\JCBER_~1\AppData\Local\Temp\RDR6BED.tmp\empty.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6BFD.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6C0E.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6C79.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6CA9.tmp.txt
Symbole d’analyse :
ID de rapport : 3229de24-9a38-4c9e-9b6b-3cafe7e8bd18
Récipient avec hachage : c7470f0f5803cc9b358f19d228307730
GUID CAB :0
+++ WER5 +++:
Détecteur d'erreurs 125730739576, type 5
Nom d’événement : PerfWatsonVS12Data
ID de CAB : 0
P1 : PerfWatsonTcdb
P2 : 0
P3 : 0
P4 : 0
P5 : 0
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\VSTelem.Out\201812070845_D16.0_16.0.28329.73_3144_10a9b079-de63-439d-a493-592007a91d94.tcdb
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCB5.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCC5.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCD01.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCD40.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_PerfWatsonTcdb_688f135dd185f2a8133a474a2518efc6ce6cc4a_00000000_0ffcd212
Symbole d’analyse :
ID de rapport : 05910759-810c-4f62-be29-fcfc2ab3d070
Récipient avec hachage : fb30d2b9a7acf0305d4da51668259751
GUID CAB :0
+++ WER6 +++:
Détecteur d'erreurs , type 0
Nom d’événement : VisualStudioNonFatalErrors2
ID de CAB : 0
P1 : devenv.exe
P2 : 16.0.28329.73
P3 : vs.taskstatuscenter.task-completed-tip-fault
P4 : System.ArgumentNullException
P5 : Microsoft.VisualStudio.Shell.UI.Internal
P6 : Microsoft.Internal.VisualStudio.PlatformUI.Tipping.UIFactory.CreateCallout
P7 : _
P8 : _
P9 : _
P10 : _
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\VSFaultInfo\181207_083924_5401559\ErrorInformation.txt
Symbole d’analyse :
ID de rapport : 32323b36-02e3-4be0-a2ae-c26cab27f890
Statut du rapport : 268697600
GUID CAB :0
+++ WER7 +++:
Détecteur d'erreurs 1802750596775480438, type 5
ID de CAB : 0
P1 : devenv.exe
P2 : 16.0.28329.73
P7 : _
P8 : _
P9 : _
P10 : _
Fichiers joints :
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7715.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7745.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7792.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER77D1.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_devenv.exe_36a384ed35c49944456d4c7618f9e829efff962_00000000_39fc7d2f
Symbole d’analyse :
Récipient avec hachage : 08f3fad674efb9fab904a81dcb6d0c76
GUID CAB :0
+++ WER8 +++:
Détecteur d'erreurs 128015651019, type 5
ID de CAB : 0
P1 : PerfWatsonHang
P2 : 0
P3 : 0
P4 : 0
P5 : 0
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\PerfWatsonHangDumpd4dcd77e-1971-4415-ac9d-4ae41fe0183e.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6E6B.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6E8B.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6F07.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6F37.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_PerfWatsonHang_4228e14e66c54c31dfb740949c9862f77bc12_00000000_0c007679
Symbole d’analyse :
ID de rapport : bc676f08-8c48-4bb7-9e6c-bdf71fee38fb
Récipient avec hachage : bf24924e654075043ccbcccc8a4ddf6f
GUID CAB :0
+++ WER9 +++:
ID de CAB : 0
P1 : PerfWatsonTcdb
P2 : 0
P3 : 0
P4 : 0
P5 : 0
P6 :
P7 :
P8 :
P9 :
P10 :
Fichiers joints :
\\?\C:\Users\jcber_000\AppData\Local\Temp\VSTelem.Out\201812060839_D16.0_16.0.28329.73_13416_f9da370f-0e9e-40e2-b559-62849e1608e7.tcdb
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER1FBA.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER1FDB.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER2066.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER20B5.tmp.txt
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_PerfWatsonTcdb_688f135dd185f2a8133a474a2518efc6ce6cc4a_00000000_30562410
Symbole d’analyse :
ID de rapport : eaaaec4f-7e38-4e1c-812a-59041e1916cc
GUID CAB
