Exception from a shapefile whose .dbf contains a "Date" field
5606
7
06-13-2015 12:05 PM
WlodzimierzSzafran
I just encountered strange behaviour when trying to use a ShapefileTable from a shapefile that has at least one field of type "Date" among the attributes in its .dbf file. Any attempt to either get a count of the features or to iterate over the features ends in an exception:
"The added or subtracted value results in an un-representable DateTime. Parameter name: t"
Steps to reproduce:
Use any shapefile with at least one attribute of type "Date", with actual dates in the data, and then:
var shapefileTable = await ShapefileTable.OpenAsync(fileName);
var features = await shapefileTable.QueryAsync(new QueryFilter() { WhereClause = "1=1" });
if (features == null || features.Count() == 0)
    // e.g. throw an exception
The relevant stack trace:
   at System.DateTime.op_Addition(DateTime d, TimeSpan t)
   at Esri.ArcGISRuntime.Internal.DateUtils.FromMillisecondsSinceEpoch(Int64 milliSeconds)
   at Esri.ArcGISRuntime.Data.ArcGISFeatureTable.RowEnumerator.<System.Collections.Generic.IEnumerable<Esri.ArcGISRuntime.Data.GeodatabaseFeature>.GetEnumerator>d__48.MoveNext()
   at Esri.ArcGISRuntime.Data.ArcGISFeatureTable.RowEnumerator.<System.Collections.Generic.IEnumerable<Esri.ArcGISRuntime.Data.Feature>.GetEnumerator>d__4e.MoveNext()
   at System.Linq.Enumerable.Count[TSource](IEnumerable`1 source)
I would appreciate if this was acknowledged as an issue and fixed as soon as possible.
Thanks, regards.
MichaelBranscomb
Esri Frequent Contributor
Good news: we have recently addressed this issue and I have verified against the latest build of the forthcoming 10.2.6 SDK. The problem was apparently null date values in the Shapefile.
Your example code now successfully reports the feature count (I added the MessageBox):
else
                MessageBox.Show(features.Count().ToString());
Cheers
Mike
MichaelBranscomb
Please can you upload a Shapefile we can test with?
Cheers
Mike
WlodzimierzSzafran
Hi Michael,
Could this be done outside of the forum? I'd like to pass a problematic file to you for testing but certainly wouldn't like to share it publicly. For example, I could give you a Dropbox link.
Thanks, regards.
MichaelBranscomb
Absolutely - feel free to email me a link to download: [email protected].
Cheers
Mike
MichaelBranscomb
else
Cheers
Mike
WlodzimierzSzafran
Hi Mike,
good to hear that the problem has been addressed, thanks for your involvement.
Looking forward to the 10.2.6 release.
Regards.
TonyGeorges1
Hi Mike,
We are experiencing the same problem when loading an SQLite geodatabase (saved from ArcGIS Online) into a FeatureTable Source.
The feature table contains a Date Range domain. Do you have any idea about this problem ?
The stack trace :
Message : TimeSpan does not accept floating point Not-a-Number values.. Source : mscorlib. StackTrace :
   at System.TimeSpan.Interval(Double value, Int32 scale)
   at Esri.ArcGISRuntime.Internal.DateUtils.FromMillisecondsSinceEpoch(Double milliSeconds)
   at RuntimeCoreNet.BinaryReaderExtensions.ReadRowVariant(BinaryReader r, RowValueType type)
   at RuntimeCoreNet.BinaryReaderExtensions.ReadRowVariant(BinaryReader r)
   at RuntimeCoreNet.CoreFeatureSource.GetDomainInfo(String domainName)
   at Esri.ArcGISRuntime.Data.FeatureTable.SetSource(CoreFeatureSource source)
   at Esri.ArcGISRuntime.Data.GeodatabaseFeatureTable..ctor(CoreFeatureSource source, Geodatabase owner)
   at Esri.ArcGISRuntime.Data.Geodatabase.<get_FeatureTables>d__0.MoveNext()
   at SOMaps.Manager.Offline.OfflineDataManager.<HasOfflineDataForLayerAsync>d__83.MoveNext()
The Code:
Geodatabase gdb = await Geodatabase.OpenAsync(path);
gdb.FeatureTables.Count()
I can share you the sqlite geodatabase if you need,
Thank you for your help,
Tony
AnttiKajanus1
Hi Tony,
Could you provide simple reproducer for this issue so I can have a look what's going on?
cheers
