Dynamic Local Layer
7450
10
07-01-2015 05:02 AM
SandeepKumar
  I am working on a offline application using ArcGIS Runtime for .NET and my requirement is to create Layer visibility control for local Base map layer. Can someone suggest me how to call dynamic local layer in ArcGIS Runtime for .NET and to display its sub layers in Layer visibility control (Layer On/Off Control).
JosephGenther
Yes, that's perfect for deployments where users are named and known to an ArcGIS portal system. Definitely ideal and the preferred method.
Use ArcGIS Online or Portal for ArcGIS to license your app if your app will be connected to ArcGIS Online or your portal at least every 30 days.
