Does Local Server SDK v200.x exist for LocalServices v200.1.0 NuGet package?
1652
11-01-2023 11:00 AM
noodle
I have an application running under Local Services 100.15.0.   I updated to Local Services v200.1.0.   When tried to compile, Visual Studio complained that
Error ESRI2000
ArcGIS Maps SDild this project.
Download anK for Local Server 200.1 component not installed. Local Server is required to bud install Local Server from https://links.esri.com/arcgis-runtime-local-server-sdk
I have Local Server SDK 100.15.3604 installed.
dotMorten_esri
Esri Notable Contributor
You need the 200.1 Local Server SDK which you can get from the link you posted above
noodle
What I see is only v.100.15.0.   Where can I find 200.1 version?
MichaelBranscomb
Esri Frequent Contributor
I hope you've found it by now, but the download is now listed under the new name "ArcGIS Maps SDK for Local Server" along with the wider rebranding of the ArcGIS Runtime SDKs to ArcGIS Maps SDKs for Native Apps.
Thanks
