Display an Image
1782
05-27-2021 07:22 AM
FlorianKowalsky
Is there an easy way to display an image on a map?
I have the four points of an rectangle an i would like to fill it with an Image thats generated in Memory.
ZackAllen
Hi Florian, thank you for reaching out. You can display an image on a map or a scene using a KML ground overlay class . We have a sample that demonstrates displaying a KML ground overlay on a scene.
Unfortunately, the  KMLIcon object currently only supports a Uri to a network or local path. You would need to find a way to write the image from memory to storage for use in the KMLIcon and KMLGroundOverlay.
Please let me know if you have other questions,
Zack
ZackAllen
Zack
FlorianKowalsky
Thanks, i still found this  solution, so i hoped there is a way without writing the Image to Storage.
