Data entered in Sql Server show in geodatabase after several hours when create offline map
765
08-06-2021 02:01 AM
KiroAndreevGDI
Dear,
When entered data in SQL Server and created offline map with C# WPF ESRI, this data not appears in geodatabase in real time. If I create offline map after 3 or 4 hours of entered data in SQL Server, the data appears. I am using next code for creating offline map:
// Create the job with the parameters and output location.
_generateOfflineMapJob = takeMapOfflineTask.GenerateOfflineMap(parameters, packagePath, overrides);
// Handle the progress changed event for the job.
_generateOfflineMapJob.ProgressChanged += OfflineMapJob_ProgressChanged;
// Await the job to generate geodatabases, export tile packages, and create the mobile map package.
GenerateOfflineMapResult results = await _generateOfflineMapJob.GetResultAsync();
How to solved this problem?
Best Regard.
